Foobar EQ plug in
strider
strider Posts: 2,568
edited November 2009 in 2 Channel Audio
Stumbled across a pretty cool EQ plug in for Foobar today:
http://www.aixcoustic.com/index.php/Electri-Q-posihfopit/30/0/
Need to download and install VST wrapper in your components folder first, which allows use of the EQ by means of a sub folder in the task bar menu at the lower right of the Windows screen. VST wrapper's here.
The EQ program has an immense amount of variables to play with, analog and digital versions, can simulate different types of crossover types, etc.
Wristwatch--->Crisco
