SDA models and room sizes
jimbo1421
jimbo1421 Posts: 772
edited November 2009 in Vintage Speakers
Hello,
There is a pair of SDA 2Bs for sale near here and I was wondering if they would work better in my living room than the SDA 1Bs I bought last summer. My entertainment center is at the narrow end of my 13' x 19' living room; there is an 8' opening to the 13' x 14' dining room at the other end.
From what I am reading SDAs need a minimum of 12'-6" to function and that 16'-6" would be much better. Does this apply to all SDA models? Or would the SDA 2, which has fewer drivers than the SDA 1B, function better in the narrower space?
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Post edited by jimbo1421 on
  • ben62670
    ben62670 Posts: 15,969
    Think triangle. The SDA's need to be the same distance from each other as from the listener. You can go a little further back if you must. Also I would try to put them on the long wall.
    Ben
    Ben
  • jimbo1421
    ben62670 wrote: »
    Ben
    So it does not matter which size model? I am trying to decide whether to go for the SDA 2Bs or stick with and refurbish the SDA 1Bs.
    Unfortunately there are two doors and a fireplace that prevent me from using the long walls and still keep them 3 feet from the side walls. 2'-8" is the best I can do. I have attached a PDF with three possible floor plans.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • ben62670
    The last one is the best. It doesn't matter which model SDA you have the same rules apply.
    Ben
  • jimbo1421
    Thanks a lot Ben. One last question — SDA 1B has two tweeters, two stereo MWs and two dimensional drivers; the SDA 2B has just one apiece. What is the advantage of having more drivers? In my sized living room would it make any difference? It would certainly be less expensive to refurbish.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • ben62670
    The extra tweeters were added to keep up with the efficiency of the MW's. Everytime you double the amount of drivers you get a 3db boost. Also the extra tweeter increases power handling. A single tweeter actually works best, but fear not the 1B's and C's work wonderfully with two tweeters.
    Ben
  • jimbo1421
    Thanks, Ben. So your recommendation would be to stick with the 1Bs that I already have? I did try the third room layout some time ago. The right side had a nice sense of space around it. The left side projected the odd sensation of sound coming out of the corner. Do you have any idea what could be done on the left to balance the sound out a little better. Full length curtains, maybe?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • ben62670
    Heavy curtains would certainly help. As for which speaker I prefer the 1B's.
    Ben
    F1nut Posts: 52,002
    The 2B's with the TL mod are damn fine sounding speakers.
