Need help cleaning SDA1 drivers
gdphoto
gdphoto Posts: 182
edited March 2010 in Speakers
Hello everyone! I have a pair of SDA1 Polk speakers. Bought them in 1987. They need a cleaning and I don't want to do without getting advise. There seems to be a white mold growing on the bass drivers, not a lot, but there's something there. What is the best solution to use for cleaning. I noticed an earlier post that said to use Windex. That seemed harsh and I didn't want to use it until I double checked.
Thanks for your help.
Hafler DH220 Power amp Recapped
Hafler DH110 Preamp Recapped
Hafler Digital FM Tuner
Virtue Audio M1 Piano CD Player
Technics SL-1210-MK5 with an Ortofon Black LVB250 Cartridge
Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
Post edited by gdphoto on
  • ben62670
    ben62670 Posts: 15,969
    edited November 2009
    Windex on a cloth or use a Q-tip.
    Ben
    F1nut Posts: 51,776
    Windex.
  • Bubinga99
    Bubinga99 Posts: 283
    Is this a white ring around the joint between the dustcap on the drivers, and the adhesive line connecting the dustcap to the driver's cone, growing into the dustcap?
    edit: like this:
    If so, I had that exact same problem. I called polk about it, and what I did was take some isopropyl alcohol and a medium stiffness artist brush, lightly dab and brush the alcohol on the white stuff.
    In all cases it was improved after 1 application, but a few of them it took 2 or 3 applications to make it mostly disappear (except on real close inspection). Wait at least an hour or so between applications, so the alcohol completely evaporates.
    Start out as light as possible (in terms of how wet with alcohol) but I had several where the white stuff seemed to go the full depth of the dustcap material's thickness and I had to soak it pretty good.
  • gdphoto
    gdphoto Posts: 182
    edited February 2010
    Thanks for the help
  • ben62670
    dexwind
    Ben
  • mjcmt
    mjcmt Posts: 44
    Vinegar or glass cleaner
  • gdphoto
    gdphoto Posts: 182
    edited March 2010
    I used Windex and soft lint free wipes and it worked like a charm. Thanks for the great advise!
  • gdphoto
    gdphoto Posts: 182
    edited March 2010
    ben62670 wrote: »
    dexwind
    Ben, When I first read this I thought you were cixelsyd.
