Can I use martin logan vignette with my onkyo 607
buymesome
buymesome Posts: 281
edited November 2009 in Speakers
Can I use 7 martin logan vignette with my onkyo 607 at low volumes for a movie or maybe just 2 of them for 2 ch listening for a couple of hours at one time
Post edited by buymesome on
  • engtaz
    engtaz Posts: 7,664
    Yes and the output will be 110 W (6 ohms, 1 kHz, 0.1%) for all channels
    engtaz
  • buymesome
    Is there any other logans I could run that would be safe ?
    I'm very excited about trying the logans especially now that I'm building up some $$$ . Thanks for the response engtaz
    tonyb Posts: 33,024
    Someone here in chicago on craigslist has some ML for 600 bucks. The CLS model,good lookers too. You might consider an upgrade in your avr first,I don't think that model has pre-outs for an amp. You will need an amp down the road, you know that right?
  • buymesome
    yes I know but the onkyo does have zone 2 pre outs
    The cls are awesome but also huge I read a bunch of stuff about Ml's and only the vignette does 6 ohm
    I saw a pair going for $350 and thought about doing the LLZ for COD MWF 2 but some one just bought the last night 1 hour after my op
  • Hawkeye
    Hawkeye Posts: 1,313
    tonyb wrote: »
    A friend of mine has had all the variants of the CLS. Don't even think of trying an AVR with these speakers. They will strangle an AVR.
    While I have no experience with the Vignette, the http://www.martinloganowners.com/forum/ would be your best source for advice on these speakers.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
