How can I conect my speakers on my PC
Luiquroj
Luiquroj Posts: 26
I want to plug my two monitor 30 on my PC, how could I can make this? Thanks
TV: Sony KDL-32LL150
Front: Monitor 50 | Monitor CS1
Center: Monitor 50
Rear: Monitor 30
Control: Sony RM-VL600
Receiver: Sony STR-DG510 5.1
HTPC
Case Armor+ Mx
Logitech Mx Air Mouse
Phenom 9950
Asus M3AT8-EM
OCZ ModXStream 600W
OCZ 6400 2GB
WD 500GB
  • jso
    jso Posts: 26
    edited November 2009
    How are you driving the Montior 30s now?
    If you have a receiver, great, you just need to run a 3.5mm cable from the PC soundcard to either a 3.5mm input on the receiver if it has it (many don't) but if not just get a 3.5mm to RCA adapter (looks like a 'Y') and plug that into one of the receiver inputs. Then you're done.
    edit: 3.5mm cable is really cheap online. I got a 25 foot one for a few bucks and that runs from my computer to my receiver.
  • Luiquroj
    Luiquroj Posts: 26
    What I want is replace my polk 30 for a pair of 40 as surround and put the 30 only for my pc (in another room)
    Center: Monitor 50
    Rear: Monitor 30
    HTPC
    Case Armor+ Mx
    Phenom 9950
    Asus M3AT8-EM
    OCZ ModXStream 600W
    OCZ 6400 2GB
    WD 500GB
  • Libertyc
    Libertyc Posts: 915
    You will need an amp or receiver to power them for the PC.
  • Luiquroj
    Luiquroj Posts: 26
    Mmm I still dont see it but is there any subwoofer with digital input? If i plug the subwoofer with this and then plug the speakers there dont u think it could work? or a rca converter and plug the input in the subwoofer? I really dont want buy another receiver =/
    Center: Monitor 50
    Rear: Monitor 30
    HTPC
    Case Armor+ Mx
    Phenom 9950
    Asus M3AT8-EM
    OCZ ModXStream 600W
    OCZ 6400 2GB
    WD 500GB
  • Libertyc
    Libertyc Posts: 915
    I'm not sure I know what your talking about. You want to hook up a pair of speakers to your computer? You need an amp to power them. A sub will not power your speakers.
