Rattling Rear Cargo window..
ChevyMan4x4
ChevyMan4x4 Posts: 52
edited April 2003 in Car Audio & Electronics
Now that I am bumping alone the rear window on my blazer is making this good awful rattling it makes my skin crawl when I am standing behind it... any cheap ways to fix it?
Sir Daniel X. Boom - the GNX slayer
Post edited by ChevyMan4x4 on
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2003
    i'm not really familiar w/ the blazer back windows but -- if it is a glass window that closes down over a rubber gasket then you can simply add more "Stuff" to the gasket.... more weather stripping, liner, something.... make it so its really ahrd to close it... be careful not to break anything, and then snap it shut with allthat extra "stuff" inthere... that should help
    if its an entire hatch.. then i dunno dude.
    The Artist formerly known as PoweredByDodge
  • Keske944
    Keske944 Posts: 134
    edited April 2003
    Are you sure it's the window? Sometimes a licenes plat can make just as much noise. It it is the plate the best htink I fount to do was put a ver thick rubber washer or a short piece of rubber hose inbetween the plate and the car/truck/van/suv/whatever. This will act as a 'shock absorber" almost and should keep your plate from rattling.
    Patience... patience...
    Screw patience... Crank the volume and floor it you panzie.
