Speaker stands for Monitor 7C's?
Pycroft
Hi all. I'm new to the vintage monitors. Are there stands that they came with, or that were made for the Monitor 7c's that I should buy? If so, if you have a set, let me know. If not, is there some model or brand that would work best.
Thanks,
James
Thanks,
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
Yes there are and hard to come by seperate but they do pop up. Do a search, there are specs if you care to build. Jstas father will also build you a custom pair all to orig specs.
Good Luck
PaulyLife without music would♭ -
I have some if you are interested....I will be back in the middle of the week to give pics, just pm me and we'll talk about it
There's your needle in the haystack.
Original Monitor stands are very hard to come by. A while back I managed to track down an original pair for my 7A's. They made a very appreciable difference in sound. The low end tightened up a lot, the highs smoothed out noticeable, the whole soundstage raised up and became a lot more coherent.
Eventually I'm going to upgrade my 7's, and I'm planning on making a beefier pair of stands for them. I'm gonna build them to the original dimensions, but much sturdier. I'm probably going to fill the centers of them with lead shot, and spike them as well.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
