Pioneer DEH-P940MP
sntnsupermen131
sntnsupermen131 Posts: 1,831
edited April 2003 in Car Audio & Electronics
ive asked on this forum once before about this radio but wanted to ask again to see if anyone had any more opinions about it
ive done some research and i like this one
especially with 6v outputs
Pioneer DEH-P940MP
$ 599.00
MOSFET 50W x 4
XM Satellite Radio Ready
Controls optional
GEX-P900XM or
GEX-FM903XM Satellite Radio tuners (as XM source)
8-character display for XM Radio text (no scroll)
Steering Wheel Remote
Soft Key Operation
Rotary Volume Control (Pop-Up)
Built-in DSP with PRO Mode
13-Band Graphic Equalizer
Frequencies: 50, 80, 125, 200, 315, 500, 800, 1.2k, 2k,
3.15k, 5k, 8k, 12.5k
Level: +/- 12dB
5 Factory and 2 User EEQ Presets: Super Bass,
Powerful, Natural, Vocal, Flat, Custom1, Custom2
Source Custom EQ memory (Independent Custom
Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
Auto-EQ (3 Curves, Microphone Included)
Digital Sound Field Control (4 Presets)
Octaver Bass Enhancement (2 Modes)
BBE (+/- 4 Step)
Time Alignment (4 Modes, 1 Custom): Adjustment range
0-160inch/1 inch steps
Digital Automatic Sound Levelizer (ASL) with Built-in
Microphone (5-Mode)
Two-Way Crossover Network (Normal Mode)
Front HPF: 50/63/80/100/125Hz, Slope -12dB/oct
Rear HPF: 50/63/80/100/125Hz, Slope -12dB/oct
Subwoofer LPF (Mono): 50/63/80/100/125Hz, Level -24
to +6dB, Slope -18dB, Phase (Normal/Reverse)
Three-Way Crossover Network (PRO Mode)
High HPF: 1.6k-20kHz, Level -24 to +0dB, Slope -12 or
-6dB, Phase (Normal/Reverse)
Mid LPF: 1.6k-20kHz, Level -24 to +0dB, Slope
-18/-12/-6/0dB, Phase (Normal/Reverse)
Mid HPF: 20-200Hz, Slope -18/-12/-6/0dB
Low LPF (Mono): 20-200Hz, Level -24 to +6dB, Slope
-18/-12/-6dB, Phase (Normal/Reverse)
IP-Bus System Control
MCD Control
TV Tuner Control
Auxiliary Input (CD-RB10 or CD-RB20 required)
2 External Unit Control
S.L.A. (Source Level Adjustment)
Selectable Fader Control
Hi-volt RCA Preouts (x3 pair, Front, Rear & Sub) (6V)
Advanced Organic EL Display (256x80 pixel)
Full-motion 3D graphic animations including:
4 screensavers (High Dive, Dune Racing, Apollo
Mission, Extreme Skiing)
4 Spectrum Analyzer displays
5 background full-motion animations
12 background pictures
Enhanced Clock mode & Off (text-only) mode
2 Display Modes (alternate screen layouts)
Form 1 includes 32-character text display
capability
Form 2 includes 2 lines of 24-character text
display capability
Adjustable brightness level (32-mode)
Customizable Display Download Capability (PC Link Kit
required)
Visit www.pioneer.co.jp/car/pclink/index-e.html for more
info
Cellular Mute Capability (CD-CM1 required)
Clock
Brushed Silver Metallic Finish
Track Scan/Pause/Repeat/Random Play
Audible Fast-Forward/Reverse
Playback Compatible with Digital CD-R and CD-RW
Disc Title Memory (48 Discs)
CD Text
AGC (Automatic Gain Control)
WMA (Windows Media Audio) & MP3 CD-ROM Playback
8x oversampling
3-beam laser pick-up
1-bit D/A Converter
Anti-shock mechanis
DIN Mountable
Detachable Face (faceplate carrying case included)
Motorized Flap Face
Supertuner III
24-Station/6-Button (18FM / 6AM) Presets
BSM (Best Station Memory)
Up/Down Seek with Selectable Local Seek Tuning
$600 off of carmedia1
cheapest i could find
anyone know where i could find it cheaper with the full warranty?
or does anyone know of a better head unit for $600?
only conditions are motorized flap face, xm ready, 3 4v pre outs(minimum)
i plan on buying it in early-mid may
so i figure by 2032 ill have all the adjustments perfect...
thanks for any input
-Cody
Post edited by sntnsupermen131 on
  • Keske944
    Keske944 Posts: 134
    edited April 2003
    You can always check ebay. A lot of times they have head units on there that are brand new and come with the factory warrenty. You may also want to check out Kenwood head units. The have Sirius not XM but they are great units. I am running an eXcelon KCD-X659 and I love it. There newest one is the KCD-X959 I believe. You may want to check it out but I'm not sure. Mine has 4.5v preouts still not bad and it play mp3's
    Patience... patience...
    Screw patience... Crank the volume and floor it you panzie.
  • sntnsupermen131
    edited April 2003
    thanks
    but id rather have the xm radio...and you can get stuff off ebay with full warranty?
    anyone else have any suggestions?
    -Cody
  • Jstas
    Jstas Posts: 14,842
    edited April 2003
    I found it here: Pioneer DEH-P940MP
    for $548.00
    It's temporarily out of stock but, by the time you are ready to get it, they may have it back in. You can always email them and ask too.
    I've found that when something is so new that the discounters sites don't have it yet or have it for retail prices, I check out this place:
    http://www.nextag.com/
    Do a search on what I am looking for and can usually beat retail prices by 50 dollars or more. Always a good site to check out for anything and much much better than places like buy.com which really isn't all its cracked up to be.
    Expert Moron Extraordinaire
  • Keske944
    Keske944 Posts: 134
    edited April 2003
    $479.00 + shipping on ebay right now with warrenty
  • sntnsupermen131
    edited April 2003
    jstas...dude you kick ****
    and what do you think about this head unit?
    lol
    im going to email them to see when theyll get them back in stock
    thanks so much man...
    keske...or anyone who knows about this:
    how do you get full warranty off of stuff from ebay?
    if its not from an authorized dealer
    cuz hell yeah ill take if for $480 over $540
    -Cody
  • Jstas
    Jstas Posts: 14,842
    edited April 2003
    It's got all the same stuff as my Girlfriend's current head unit plus a whole lot more. I'm very satisfied with her head unit and I can only imagine that this one is just as good if not better. I still haven't figured out all of her settings yet so you will probably messing with it until 2035, like you said! If you can get the full-warranty for the 479 or whatever from ebay, go for it. If not, that price from that site i found on nexttag.com is 150 of of Retail and like 200 off of MSRP.
  • Keske944
    Keske944 Posts: 134
    edited April 2003
    The buiness should send you a reciept or an invoice showing the date you bout it and the prive you paid. The buiness should be an authorized Pioneer dealer if they are offering the warrenty and you just register the head unit with pioneer (i'm not sure if they have a web site or whatever). Hang on to the reciept and if anything goes wrong take it into your pioneer dealer (local) along with your registration and they should get it taken care of. Most companies won't do a thing without the reciept and the regestration.
    Hope this helps.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2003
    Keske -- you're having a baby?
    CONGRATULATIONS!!!!!!!!!!!!!!!!!
    .... a boy or a girl (or are u waiting to find out?)?
    The Artist formerly known as PoweredByDodge
  • sntnsupermen131
    edited April 2003
    thanks a lot everyone
    I plan on getting it as soon as electronics city gets them back in stock
    i emailed them yesterday but havent received a reply yet
    i think half of the shipping is going to be the weight of the manual that goes with it...
    that thing probably has more memory than this computer does
    lol
    and i checked out ebay and all of theirs were refurbished
    and ill just as soon get the brand new one
    i need $25 more though
    so by next week ill be good to go
    if they get them in
    thanks again everyone
    -Cody
  • Systems
    Systems Posts: 14,873
    edited April 2003
    good pricing there in your place man
    in my country it is selling for 2k++ the price is damm high
    if any want to contribute an HU pls do let me know
    rdg,
    looseman§
    Testing
    Testing
    Testing
