Speaker Protection
Pauly
Pauly Posts: 4,519
edited November 2009 in Speakers
I use this for the tops of mine. Good, cheap, effective, cut to size, no slip, great for Pics and stuff that will scratch. Think its rubbermaid. Been using for while and dont recall. Local Target or Walmart on the cheap. I just thought about it and wanted to share.
non-slip-tool-box-cabinet-drawer-liner-12-wide-tm11-toolmate-73-p[ekm]314x300[ekm].jpg
Pauly
Life without music would
Post edited by Pauly on
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Got the same stuff lining the drawer's of all my tool boxxes :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Pauly
    Pauly Posts: 4,519
    Bought for cabinet and drawers in apt and had extra and figured it could serve on top of my Polks.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Why would you set anything on top of your speakers to begin with?
    Yeah, who knows on Carlin, let me look. I've sobered up since.
    Cheers,
    Russ
    treitz3 Posts: 19,992
    Be careful setting anything heavy on top of those. When certain moisture or temperature conditions happen, you may just one day lift them off and discover a pattern that's not easy to remove, if at all depending on the substrate it's set on
  • Pauly
    Pauly Posts: 4,519
    RuSsMaN wrote: »
    Hey if i had the opportunity to set a hot piece of tail atop my speakers and do my thing they would need some sort of protection. This is just another factor of speaker protection for those who like to set stuff atop their speakers.
    Glad you sobered up. I havent. Lets have a drink.
    Pauly
  • Pauly
    Pauly Posts: 4,519
    treitz3 wrote: »
    I dust 3 times a week those included and nothing heavy i agree.
    Edit.
    I put the "sticky" side up BTW
    Double edit.
    I live in Florida and have not had any problems. About as humid as it gets. :)
    P
  • RuSsMaN
    I haven't found anything hot enough to 'soil' any audio gear, and yeah, my standards are pretty high. There are plenty of other things she can sit on, but don't mess with my speakers.
    Bottoms up.
    Cheers,
    Russ
  • Pauly
    Pauly Posts: 4,519
    Thats why you need protection my friend. Well at least i i Do. Guess i need to sober up........ Nah
    P
  • adambrown81
    adambrown81 Posts: 3
    Hi Pauly,
    I think great advice from your side,well I had never try such type of protection for the speakers and I try to clean them twice in a week.Well i am plan to switch to our advice,if you have more ideas regarding that just reply me.
