Problem with my RTiA9 and Tech Support is closed already :(
SolidSqual
Ok, just got the RTiA9s in and opened them up to have a look. The cabinets are flawless despite being Refurbished units. Unfortunately one of the speakers had something rolling around inside that sounds like a piece of wood clapping back and forth when I tilt the speaker side to side. Upon further inspection it seems there is a black plastic cylinder that is rolling around inside.
The Cylinder is evidently slotted and fits into the grooves of the front port. My first question is whether anything else could have come loose inside the RTiA9 that is associated with this piece and whether all I need to do is guide this tube back on to the port slot from which it came.
Should I secure the cylinder with glue? What kind of glue? Should I reinforce the other speaker as well? To do this should I unscrew the port and glue it that way and then re attach the port with the cylinder attached?
Or, is the cylinder the sign of more serious damage that might require Polk sending me a new speaker?
Regard,
Mike
Regard,
Mike
Post edited by SolidSqual on
resecure the cylinder with a good epoxy cement. Simply unscrew the port and resecure with the cylinder attached. Call Polk in the AM and they will send you a new one. I doubt there will be any other issues.
... The beer is on you!:p and congrats on the fine speakers. Post some pics or it did not happen.
JohnThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
what john said, and congrats on the a9spanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
What they said, you should be good to go. No super glue or anything that could dissolve a petroleum based plastic - regular old white glue should do the job fine.
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
