How much is to be gained by replacing Monitor x-overs, etc?
jbarbier
jbarbier Posts: 9
edited November 2009 in Vintage Speakers
Hi guys!
I have a very modest system (as a college student) consisting of a pair of 1986 Monitor 5B speakers, an NAD 3020 integrated, Harmon Kardon CD player and a Pro-ject Debut turntable. I upgraded to my Polk speakers from an early 1970s pair of Bose 301s and really started to enjoy music.
My 5Bs sound immensely better than the Bose speakers and I'm very, very happy with the way they sound right now. However, I keep reading about upgrading the crossovers with new components, and even swapping the tweeters to RDO194. If if decide to go through with the upgrades, how much of a difference do you think it would make?
I ask because I am in NO way unhappy with the way my speakers sound, but if they could sound even better, I'll do it. :p
Also, if I'm replacing the components in the crossover anyway, would it be better to opt for the RDO198 tweeters?
Thanks. Justin
Post edited by jbarbier on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I don't think you'd be able to use the RD0198's without doing some fairly extensive modifications to the crossovers.
    The 194's are some nice sounding tweeters. FWIW, I'd do the tweeters before the XO's.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • jbarbier
    jbarbier Posts: 9
    Wow, that was fast. But that's interesting, because it seems like almost everyone I talk to seems to claim that the caps will go bad after a couple decades.
    I'm pretty comfortable with refurbishing electronics (sometimes just for fun.) I'll usually go around to garage sales and buy vintage equipment and fix them up.
    My ear, however, isn't that great. I've been playing drums for about 15 years now so my hearing isn't the best as far as picking up inaccuracies or "weak" spots in music.
    I do have a good ear for discerning what sounds good and what sounds bad, though.
  • kcoc321
    kcoc321 Posts: 1,788
    I have heard apair of 5's with the upgraded cap and tweeters and I have to say they where very detailed, say a 200% improvement, sounded amazing.
    As far as the tweeter change, I am considering that on mine and to me, it does not seem that much work. Just look to the Mon 5 series II with the SL3000 wiring diagram in the Vintage speaker section.
    http://www.polkaudio.com/forums/attachment.php?attachmentid=18767&d=1155784608
  • jbarbier
    jbarbier Posts: 9
    kcoc321 wrote: »
    Wow. I know things like this are subjective, but if it is that much of an improvement for about $150, I think I might just go ahead and do it. I also thought about building new enclosures (or modifying the originals.) Love these speakers!
  • NJPOLKER
    NJPOLKER Posts: 3,474
    Just re-build them and thank us later. Do a few searches and see some of the work done by fellow members on their 5's. As I remember one of the fellow members show exactly what and how to that x-over.
    heiney9 Posts: 25,408
    Just do it. You can use Clarity Caps "PX" series which are an excellent sounding budget capacitor. And get the RD0194-1, you can't use the RD0198-1. For less than $150 and little of your time you will be amazed at the improvement.
    The avg life expectancy of an electrolytic cap is about 12 years give or take and based on use. So, yes the caps are at the end of their useful lifecycle.
    here you go:
    http://www.polkaudio.com/forums/showthread.php?t=51420&highlight=upgrade
  • NJPOLKER
    heiney9 wrote: »
    The avg life expectancy of an electolytic cap is about 12 years give or take and based on use. So, yes the caps are at the end of their useful lifecycle.
    here you go:
    You sure make it easy for them!!
  • Face
    Face Posts: 14,340
    Depending on the parts used and the associated gear, it can be a night and day difference.
  • kcoc321
    jbarbier wrote: »
    As addition to the x-over, the ones I heard also had additional internal damping, Mortite and some internal dowels added for support. Geoff (in SEA) did them. I "think" there was a thread about them here. I'll look later if you can't find it.
  • NJPOLKER
    Just remember too much additional support/bracing is not good.
  • Face
    Face Posts: 14,340
    NJPOLKER wrote: »
    I don't believe that to be true. An enclosure should not resonate with drivers, it adds coloration and takes away from imaging.
  • NJPOLKER
    Face wrote: »
    I think you are wrong. Do you want to take one guess as to how I know your wrong?
    Nope
    Jesse said so :)
