Opinions needed: New BB/Pellet rifle
mmadden28
mmadden28 Posts: 4,283
edited November 2009 in The Clubhouse
I'm looking to buy a new BB/Pellet rifle (strictly for target practice-not hunting).
I prefer higher power/speed and accuracy with the ability to add a scope. Single pump (or at the most 2-3 pumps) for full power. Standard .177 cal BB/pellets.
Long ago I had a Crossman Air17 single pump that resembled an M16 (like this). It was pretty accurate too for not having a scope I was able to pick off a bottle cap at about 100' (or something-I never measured it). I do miss that thing-I can't remember what ever happened to it.
Any suggestions? Brands to avoid? Places to purchase? (Dick's seems overpriced). I'm not trying to break the bank here-just trying to satisfy an old pasttime.
____________________
Pool: Atrium 60's/45's
Post edited by mmadden28 on
  • Sherardp
    Sherardp Posts: 8,038
    Why not a nice 22 cal rifle. Cheap ammo to boot
  • kawizx9r
    kawizx9r Posts: 5,150
    sherardp wrote: »
    why not a nice 22 cal rifle. Cheap ammo to boot
    ^^^ +1
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • NJPOLKER
    NJPOLKER Posts: 3,474
    You can use CB rounds in the 22 if you get a good bolt action or single shot.
    billbillw Posts: 7,550
    Unless you go with a spring/air rifle, you will typically have to pump 8-10 times to get 'high velocity' (800+fps). Springers are only one **** and achieve full velocity from that ****, but the problem with spring air rifles is accuracy. They require careful holding technique and careful matching of ammo. Some people are never able to achieve good accuracy with them. You might consider a CO2 or pre-charged pneumatic (PCP). They are powerful and accurate. PCP rifles require you to pump (or charge from a scuba tank) an air chamber to high pressure (2k-3k psi) and then you can get many shots before recharging. Crossman makes one called the Benjamin Discovery that is about the most affordable one out there. They sell it with a hand pump. That Discovery model is unique in the fact that it can also be run from a CO2 charge.
    Most of the single pump air rifles are for target shooting and are pretty low velocity (<500fps). Daisy makes some very accurate single pumps under the Avanti name, but they are pricey. They also sell one (953) under the Daisy name that more affordable, but not as accurate.
  • BIZILL
    BIZILL Posts: 5,432
    I read nothing but good on the GAMO break barrels. check into them. i believe some are even silenced. otherwise these can be as loud as a 22lr.
    http://www.gamousa.com/product.aspx?product=Whisper&productID=234
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Disc Jockey
    Disc Jockey Posts: 1,013
    I own one of the Gamo break barrels and love it. 1000fps, not too loud, and highly accurate with RWS pellets.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • steveinaz
    steveinaz Posts: 19,545
    RWS 34. I love mine, super accurate break-open barrel. It will accept tip-off scope rings, but the iron sights are very, very nice, micro-click adjustable for windage/elevation. It is a "pellet only" gun, single pump, 1000fps. At 15yds I can cover my groups with a DIME, and that's with open sights.
    Do not dry-fire this type of pump gun. Also do not leave it cocked for extended periods of time.
    http://www.pyramydair.com/p/rws-34-air-rifle.shtml
  • mmadden28
    Sherardp wrote: »
    kawizx9r wrote: »
    ^^^ +1
    Can't shoot firearms in the township limits. This is for shooting in my backyard (over an acre) so I have to keep it real (and not sound like a gun firing either)
    I did see some 22 cal pellets though-I didn't know they made them larger than the .177.
    NJPOLKER wrote: »
    What's a CB round?
  • mmadden28
    billbillw wrote: »
    Hmm, PCP--I didn't even know that was an option. I owned a CO2 handgun back in the day but I hated it mainly because it sucked in the winter when the air pressure was greatly diminished-so in my head I ruled CO2 out altogether. I never knew they did this PCP thing-so kind of like Paintball but with different ammo. That sounds cool--I'm looking into that.
    I never would have thought a hand pump and a gun would go together--interesting. Sounds liek a PITA. How many shots would you get with a hand pump gun or a PCP before refilling??
    As far as break barrel accuracy goes, I just saw this on Crosman's site where they use Nitrogen instead of a spring for better accuracy and less noise--up to 1000fps with .22 and 1200fps with .177. Sounds intriguing.
    tonyb Posts: 33,072
    Don't bother....you'll shoot your eye out.
    F1nut Posts: 51,780
    Ya'll need to review the rules.
    Forum Rules
    1) Stick to the topic of the forum. This way information is easily categorized to make it easy for new members to access. Threads or posts that do not contain relevant information will be removed.
    2) The discussion of politics and religion is not allowed on this forum.
    3) Pornography and violent images or discussions are not allowed on this forum. This includes posts about weapons or explosives.
    That's a stretch. An air rifle for target use? Common...
    Well, if this is going to get locked, let me say this:
    mmadden28, www.pyramidair.com has everything you need from reviews to equipment. You can also find a lot of useful info at www.gatewaytoairguns.com (GTA forums) and also www.airgunweb.com
    PM if you have any questions. I really got into airguns last year and tried out several breakbarrel and pnematic rifles before settling on a pair of .22 cal rifles. One pnematic, one springer.
  • mmadden28
    tonyb wrote: »
    Hehe
    oh man the stories I have of playing (without regard for safety) with these things as a kid...
    To this day, I still have a BB in my hand--Makes a good story esp when educating my boys on safety. You can feel it too and whenever I let somebody they freak out :D
  • mmadden28
    I didn't consider a BB gun a weapon, esp for its intended use, considering you really only have to be 10 years old to use one (and the cub scouts allow even 6 year old entry level Tiger Cubs to shoot them). I consider it a sport.
    Anything can be considered a weapon-remember what was (or still is) banned by the TSA from taking on a plane???? Aren't speakers used as weapons against insurgents, playing Barney and what not? Hmmm. :p:rolleyes:
    Things that you have to have a license for? That's a different story, but if its perceived as a weapon, then I'll cease the topic of discussion.
    In any case, thanks so far to all for the the info, suggestions and links--its got me on the right track. Thanks for the offer there billbillw, I'll PM you with any questions I have as I progress in my research.
  • obieone
    obieone Posts: 5,077
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/wzDmdpzHusA&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/wzDmdpzHusA&hl=en&fs=1&&quot; type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  • steveinaz
    How firearms get lumped in with "**** and Violent images" I have no idea. A pellet rifle is neither a weapon or a firearm.
    tonyb Posts: 33,072
    One vote here for just the ****....ya with me?
  • Cpyder
    Cpyder Posts: 514
    Here's your solution: Buy a Ruger 10/22 for $180 bucks. Fill up a small pop bottle with loose cotton, duct tape it to the end of the barrel. Buy some subsonic ammunition and let the fun begin.
    Disclaimer - My plan may include a felony or two.
  • superjunior
    superjunior Posts: 1,632
    here's what I got, the rws diana 350 magnum - shoots 22 cal pellets at 1250 fps. single **** spring action. 1 bad **** rifle, it has the feel and accuracy of any fine made high power rifle - love mine
    http://www.pyramydair.com/p/rws-350-magnum-air-rifle.shtml
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
    Nice rifle, but your lucky if you are even hitting 900fps with a standard weight .22 cal pellet. That 1250 is for lightweight .177 pellets. That's not a bad thing because air rifles get much less accurate as the pellet speeds approach the sound barrier (~1125fps). 800-900fps is the best for accuracy. My tuned B26 shoots JSB Diablo Exacts at around 825fps and its devastatingly accurate.
    The only air rifles that are shooting .22cal pellets at 1250fps are the high end PCP rifles like the AirForce Condor.
