need help
Now I have
csi5 center
rti10 front
rti6 surround
psw404 sub
receiver Pioneervsx-94txh
DVD Pioneer DV-47ai
Blu-ray Sony BDP-S350
TV LG 60pg60 Plama
My question is:
I feel the receiver don't have enouth power for rti10
I sold my vsx-49txi got the vsx-94txh because the HD-audio decode.
Because I use the 49txi sound is really good. Now not even I play the blu-ray movie
I also have pair "audiosource Amp Two " Amp. Each can bridge to 200w
If I use the pair Amp to drive the pair RTI10, much better?
Or should I buy a powerful 5 channel Amp to drive then.(receiver use as a pre-amp)
I use 50% for music 50% for movie.
csi5 center
rti10 front
rti6 surround
psw404 sub
DVD Pioneer DV-47ai
TV LG 60pg60 Plama
My question is:
Post edited by john2009 on
Welcome John. Get a 200wpc 5 channel amp and be done with this particualar upgrade.
Brands to look at are Rotel, Parasound, Outlaw Audio, Emotiva, Sunfire, Nad, Adcom, B & K.
If you don't mind buying used, check out www.audiogon.com. You can get more bang for your buck that way.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Welcome to the Club!
A Rotel 1080 amp would work for you.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Rti's can benefit from some more power,but first,have you checked all your settings ? Are you listening to music in 2 channel or 5?HT SYSTEM-
lsi 9's -
I would try the amps you have first, then see how you like it. If this doesnt do it for than try the above suggestions.Most of them only hear how loud it sounds, and the rest of us hear everything else - :rolleyes:
thanks everyone
I use 2 channel for music "pure direct" mode
How about bi-amp? much help for music?
