change 10a's to 10b's?
warlocks1
warlocks1 Posts: 1,284
edited April 2003 in Speakers
I have an extra pair of monitor 10a's and a couple of sl2000 tweeters. I saw a pair of 10B crossovers on Ebay. What would happen if I kept the 6500 drivers and switched the tweeters and crossovers? Would it improve the sound? These are extra speakers and I don't want to put a lot of money into them, just thought it might be interesting to try. What do you all think? Thanks, Jeff
Post edited by warlocks1 on
  • burdette
    burdette Posts: 1,194
    edited April 2003
    Why not try the cheapest alternative first.. just swap out the tweeters and see how that sounds.
    F1nut Posts: 52,002
    edited April 2003
    If you just swap tweeters or drivers without the right crossover they will not perform as well. I don't know about using the 6500's instead of the 6503's, you should consult with Ken Swauger about that.
