CSi5 with rt800i's???
yaleforks
yaleforks Posts: 8
edited November 2009 in Speakers
Just purchased my first set of Polks.
I have 2 Rt800is as mains.
2 RT5s as surrounds.
1 c275 center channel.
The center has problem with one of the drivers. The spider has torn off the basket and it doesn't look like an easy fix. I found a Csi5 for under 100 dollars in my neck of the woods. How bad or good would the csi5 match with the RT800i.
Post edited by yaleforks on
  • bassaholic
    bassaholic Posts: 315
    CSi5 for under $100. I say go for it. I've run one in my RTi set-up and it sounded great. Make sure you've got the room....it's a dandy of a speaker.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
  • comfortablycurt
    comfortablycurt Posts: 6,745
    The CSi5 will match up very well with the RT800i's.
    For less than $100 it's a steal! I say go for it!
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
