In-wall center help
rgswf
rgswf Posts: 2
edited November 2009 in Speakers
I'm thinking of using RC85is as the front L/R. Should I just use the same as the center or is there another one you recommend that matches? I'll probably use RC85is as the rears as well unless I could get by with something a little cheaper. Also, if using the RC85is as the center, does anyone sell just a single or will I just have to buy a pair and deal with having an extra that maybe I could unload?
I'll be using these with the Onkyo RC160 AVR.
Thanks.
Post edited by rgswf on
  • vc69
    vc69 Posts: 2,500
    I would use the same as L/R.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
