Listening Modes
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited November 2009 in Electronics
So with my new receiver on the way on Monday, I have been going over the manual and for the life of me can not figure out which settings to use for what. You have Dolby Digital, THX, THX Surround, THX Music DTS, and so on and so on. What settings do I want to use for a movie and concert? I would think the DTS setting would be best for concerts and movies that use that, and star wars would use THX but I am not sure. Can anyone simply break them all down for me? :confused:
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • BlueFox
    BlueFox Posts: 15,251
    You use whatever the DVD supports. If it supports more than 1 format use whichever one sounds best for you. For example, a regular DVD might have both Dolby Digital and DTS. I would use DTS because to me it seems to be a bit better. On BluRay use the lossless format if it also supports any lossy formats.
    For music you can play with the settings, but direct or stereo is probably best for accuracy.
  • danz1906
    danz1906 Posts: 5,144
    BlueFox wrote: »
    Thats correct......great advice!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • bigaudiofanatic
    Ya for music I only use stereo, best IMO but i was just wondering about the THX modes like are they supposed to be better than the Dolby mode? I was reading that the THX fills in missing info but do not know much about it other than that and the fact that the receiver that have that are pretty powerful.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Face
    Face Posts: 14,340
    bluefox wrote: »
    for music you can play with the settings, but direct or stereo is probably best for accuracy.
    +1..
  • bigaudiofanatic
    So I take it the rest of the setting are worthless or not worth using?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
