Caps for Monitor 7B crossover
edited November 2009 in Vintage Speakers
Hi,
This is my first post on this forum, which I´m very happy to have discovered. I live in Brazil, and I bought my first Polks in Washington DC in 1980 - a pair of Monitor 7Bs, and I still enjoy listening to them. They are great, and have survived several international moves and (thanks to the rubber surrounds) the intense heat and humidity during the last 20 years in Rio de Janeiro. About 10 years after I bought them, one of the tweeters went out, and the Washington DC dealer then sold me a replacement that has the Polk logo, but a brushed silver base and a translucent dome that are different from the original. So, my pair of Monitor 7Bs are running with different tweeters.
Recently, the other one of the pair began to produce very reduced and distorted output fromthe woofer. I suspect that I need to replace the crossover capacitors. I discovered that a seller on eBay (http://cgi.ebay.com/Polk-Audio-Monitor-5-7-RTA-8T-Upgrade-Kit_W0QQitemZ260502434325QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca727b215) offers cap replacements. I would very much appreciate any opinions on this option.
Post edited by billinrio on
Welcome!
    Depending on how much you want to spend, you could check out http://www.madisound.com/catalog/index.php?cPath=404_5_351 . They have replacement resistors also. There are a few topics on here on X-Over upgrades for 5B's. They are fairly easy to do if you can solder. By the way welcome to the forum billinro. I'm sure others will chime in soon.
    I've bought his replacement kits for my monitor 7 & 10's. I was very pleased and now just bought a set of caps directly from Madisound for my sons Polks 7's. The new caps cleaned up the mudiness. For someone like me who is electronically illiterate but yet know how to solder, the kits were the way to go.
    Thank you for your replies to my post. I just received an e-mail from the eBay seller of the capacitor replacement kit (his name is Ray). He says that "A faulty capacitor in the crossover will not not cause little output from the woofer. I suspect, you have either a faulty woofer or amplifier. Is this correct? If so, where should I look in order to find a replacement woofer for my Monitor 7B?
    Polk still sells replacement drivers. Remove the driver, read the part number off the back, and give Polk a call. Be sure to mention that you're a Club Polk member for a discount.
    As for that kit, I would pass. You could do a lot better for only a little more.
    Except for the "Polkaudio" logo, the printing on the back of the woofer is illegible. On the front rubber suspension,there is "polk" and "SR142/17". Might the latter be the part number?
    Pull the other woofer. It should should out with MW65 followed by two more numbers, 00, 02, etc...
    With a jeweler´s loup I can just make out "Monitor Series Driver MW8 (maybe 6) 500"
    It's a MW6500. They're still available as far as I know.
    I recently spoke to Polk CS about the MW6500 replacement. They no longer have the MW6500 but the MW6503 is a compatible replacement. I was told that they have the same theil small parameters.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
    Thanks very much for the information.
    According to a post in the AudioKarma forum, the specs for the two drivers are:
    Driver model #MW 6500
    Fs: 31.0000 Hz (Free air resonance)
    Vas: 2.6486 ft^3 (Compliance volume)
    Qts: 0.2190 Total Q
    Qms: 1.3000 Mechanical Q
    Qes: 0.2640 Electrical Q
    Sd: 0.0130 M^2 (Piston area)
    Xmax: 3.1800 mm (Cone excursion, linear)
    Revc: 6.5000 ohms (DC resistance)
    Znom: 8.0000 ohms (Nominal impedance)
    Pmax: 35.0000 watts maximum rated power
    Driver model #MW 6503
    Fs: 29.8600 Hz (Free air resonance)
    Vas: 3.0017 ft^3 (Compliance volume)
    Qts: 0.3100 Total Q
    Qms: 1.7680 Mechanical Q
    Qes: 0.3760 Electrical Q
    Revc: 6.5400 ohms (DC resistance)
    It appears that the Q's and compliance of the two drivers are quite different. Will this make an audible difference in their performance? Will I need to replace the working driver as well (ending up with unmatched woofers as well as unmatched tweeters)?
    I have discovered after submitting my original posting that the problem is not the crossovers of my Monitor 7B speakers. Rather, both of the woofers have issues. One of them is "frozen", with no displacement whatsoever of the cone. The other has developed a tear in the butyl surround. I have written to Polk CS and am awaiting their response. I suspect that they don't have any more of the MW6500 drivers. If another, such as the MW6503 is available, I wonder if that option would require modification of the crossovers.
    Frozen drivers are often the result of a speaker that was dropped or mishandled.
    billinrio wrote: »
    My Monitor 5's MW6500 were replaced by MW6502. I can't hear the difference.:)
    Polk CS told me that the MW6500 and MW6503 are 8 ohm (6.5 ohm stated above) and the MW6502 is a 4 ohm. Is this true?
    Stan
    Main 2ch:
    HT:
    Other stuff:
    skrol wrote: »
    Not sure the data is correct:confused:
    http://www.audiokarma.org/forums/showthread.php?t=65109&highlight=mw6500+mw6502
Welcome!
Welcome!
