vm30 vs RTAi 7
manjax77
manjax77 Posts: 4
edited November 2009 in Speakers
Which one is better for 2.1 front speakers. Any input appeciated
Post edited by manjax77 on
  • domflane
    domflane Posts: 653
    I like the rti's
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • MADGSF
    MADGSF Posts: 603
    I have not heard the RTi-A7 but I did an extended in home demo of the VM-30. This gave me plenty of time to compare them to my RTi-10s, the precursor of the A7. I liked the VM-30 and thought they had great imaging and kind of a SDA type effect since they had multiple drivers.
    This last point I think is key for your application since you will not have speakers behind you. I think the VM-30 with a GOOD sub would do well in your application. The SDA effect I mention will give your system a surround type sound. I cannot emphasize enough that if you choose the VM-30s you will need a quality sub to round out the sound.
    In my case I preferred my RTi-10s to the VM-30 with the caveat you must have proper amplification to drive them. If you are driving them with a receiver then you could also give a listen to the RTi-A5, which I also demo'd and liked but I have rear speakers. You should listen to whatever you are going to buy if possible but I feel the VM-30 with a good sub would be good for your application.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • leroyjr1
    leroyjr1 Posts: 8,785
    I'd go with the RTI a7's.
