pioneer head unit
Systems
hey everyone i have a 03 ford escape with 3 pioneer 12 in, dvc the silver ones hooked to a new mtx 500d mono that i replaced with a 250d i want a nice head unit but don't wont to spend a fortune on it what do you think about a pioneer p3500
Testing
Testing
Testing
Testing
Testing
$160 new w/ warranty @ www.carmedia1.com
probably the cheapest place u can find
Pioneer DEH-P3500
$ 159.00
CD Multi-Color
Display /
MOSFET50 /
EEQ,
Supertuner III
/ Card Remote, Rotary Volume Control / Flap Face and Detachable
Face Security
MOSFET 50W x 4
Disc Changer Controller
Card Remote
EEQ Performance Chip
3-Band Equalizer
Easy EQ (EEQ) switches 5 Factory, 1 User EQ
Presets (Super Bass, Powerful, Natural, Vocal, Flat,
Custom)
Source Custom EQ Memory (Independent Custom
Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
Selectable FIE (Front Image Enhancer) (Rear LPF
100/160/250Hz)
S.L.A. (Source Level Adjustment)
Selectable Fader Control
RCA Preouts (x1 pair) (2V)
Large Multi-Color Liquid Crystal Display with LED Backlight
Clock
Track Scan/Pause/Repeat/Random Play
Audible Fast-Forward/Reverse
Playback Compatible with Digital CD-R and CD-RW
AGC (Automatic Gain Control)
8x oversampling
3-beam laser pick-up
1-bit D/A Converter
Anti-shock mechanism
DIN Mountable
Detachable Face (faceplate carrying case included)
Flap Face
Supertuner III
24-Station/6-Button (18FM / 6AM) Presets
BSM (Best Station Memory)
Up/Down Seek with Selectable Local Seek Tuning
the only thing i dont like is the one pair of 2 volt preouts
if it was me...i wouldnt pick this radio...i would try to get 2 4volt pre outs
but for $160...i dunno...thats just me
-Cody -
i went out and did a little research on the carmedia1 website
the radio i would go with:
Pioneer DEH-P740MP
269.00
MOSFET 50W x 4
XM Satellite Radio Ready
Controls optional
GEX-P900XM or
GEX-FM903XM Satellite Radio tuners (as External unit)
8-character display for XM Radio text (no scroll)
Card Remote
Rotary Volume Control (Pop-Up)
3-Band Parametric Equalizer (Adjustable Level,
Frequency and Q Factor)
Easy EQ (EEQ) switches 5 Factory, 2 User EQ
Custom 1 and Custom 2)
SFEQ (Sound Focus EQ)
Additional Independent Bass / Treble Control for Front /
Rear
Two-Way Crossover
Front/Rear HPF (50/80/125Hz, -12dB/oct)
Selectable LPF (Low Pass Filter) (50/80/125Hz,
-18dB/oct)
Sub-Out Level (-12dB to +12dB) and Phase Control
Independent Subwoofer Outputs
IP-Bus System Control
MCD Control
TV Tuner Control
Auxiliary Input (CD-RB10 or CD-RB20 required)
2 External Unit Control
Hi-volt RCA Preouts (x 3 pair, Front, Rear & Sub) (4V)
Organic EL Display (128 x 33 pixel)
Full-motion 3D graphic animations including
2 screensavers (Dolphins, Sky Dive)
2 Level Meters
4 background animations
Clock Display and Off (Text-only) modes
16-character text display capability
Adjustable brightness level (16-mode)
Cellular Mute Capability (CD-CM1 required)
Clock
CD Compatibility: This unit will play standard audio (16-bit,
44kHz, PCM) CDs, finalized CD-Rs and finalized CD-RWs, and
it will play finalized CD-Rs and finalized CD-RWs that contain
MP3 audio files.
Disc Title Memory (48 Discs)
CD Text
MP3 CD-ROM Playback
8x oversampling
1-bit D/A Converter
MP3 File Playback
it has 3 4 volt outputs which is what you really need if you have subs
the 2nd one i would get over the 3500
solely b/c it has 2 2volt outputs and its only $10 extra
Pioneer DEH-P350
169.00
MOSFET
50W x 4
Disc Changer
Controller
Card Remote
3-Band Equalizer
Easy EQ (EEQ) switches 5 Factory, 1 User EQ Presets
(Super Bass, Powerful, Natural, Vocal, Flat, Custom)
Source Custom EQ Memory (Independent Custom Memory for
each source)
100/160/250Hz)
RCA Preouts (x 2 pair, Front & Rear or Front & Sub) (2V)
Clock
8 x oversampling
1-bit D/A Converter
DIN Mountable
Flap Face
Supertuner III
all this info is off the carmedia1 website
-Cody -
lol cody just steps up 5 models... lmfao.
the 3500 really is a poser deck... 1 preout is cheesy bud, cody is way right, if you ever wanna use this deck for anything "useful" in the future, u need dual outs - preferably 4 v.
its not lik eyou're gonna die without it, but for like 70 bucks difference, its really worth the cost... that is a decision that u gotta make for yourself though.
but think about this -- you're gonna get a lot more "sound shaping and tweaking" tools with the 7400 -- more ways to make the music sound the way you want it to.
and i'll tell ya, there's nothin like sittin the car and going "u know there just isn't enough sound at 12.5 khz... i wish i could just boost it a tiny bit right there" and then finding out that you're deck doesn't have the capability to do that.
if u never see yourself adding a 2nd amp, and u dont care if you have some cool tweaking accessories / sound shapers, then go w/ the 3500 -- hell u could do the 2500 for all it matters, they're pretty close and the 2500 is cheaper.
but if u really want the edge - somethin like the 7400.
also... why'd u downgrade the amp?????? 4 ohm dvc = 8 per sub / 3 = 2.6666 ohms... 500D does like 700 watts at 14.4 into that load... thats a hefty 230 a sub.... the 250D takes u down to like 115 a sub. like if it died and u had to replace it, i can understand but if u just up and changed em for no reason i'mma be sittin here goin "what the heck?"The Artist formerly known as PoweredByDodge -
I have the DEH-7300 in my girl's car and it is basically the older model of the 7400. She wanted the 5400 which was comparable to 3500 but its bonus was it had some EQ settings and a pretty dolphin swimming on teh screen. Couldn't get that one and the guy told me he had them and didn't. So he sent me a 7300, for teh price of teh 5300 that he didn't have. So I got a 463 dollar CD deck for 249 bucks.
Anyway, moral is, I'm glad the guy sent me teh upgrade. It is a much nicer deck than the dolphin one and has plenty of capability. If I hadn't gotten this deck, I would be able to run the Hifonics amp in her car that I am now.
Spend teh extra cash. A good head unit will go a long way and if you don't abuse it, it will last a very long time. My Kenwood eXcelon head unit is almost 6 years old and still looks and operates like it was new. The CD Changer is 8 years old and doesn't have the best operation in ejecting the cartridge but it operates just fine. I'm glad I spent the extra money there because I have one hell of a nice head unit that still competes with th new stuff out there.Expert Moron Extraordinaire
i've got the 5400 in my grandfathe'rs truck -- its nothin special.
it does have dual outs though -- 2 volt, but at least dual... one is a sub out, the other is full range.
it beats the piss out of the kenwood 3000 series he had in there before this.
i only paid 10 bucks for this deck...lol...the internal amp chip was shot to hell and it took me 2 days just to get the deck to power up and output sound, but hey -- it onlycost me 10 bucks! and it works great! (just cant hook up any speaker to it, but i've sworn to use amps for the rest of my life anyway).The Artist formerly known as PoweredByDodge -
lol....only 5
but still
thats the cheapest one with 4v pre outs
if u cant afford it...at least get the one that has dual 2v pre outs
-Cody -
I'm sorry swapped a 250d with a 500d i will check out those head units thanks everyoneTesting
Testing
Testing -
I wasa just on ebay checking out specs on a couple of p3500 pioneers and they all have 2 rca outputs front and rear or front and subwoofer someone here said it only has 1 out put. It says it has high pass for the front and low pass for the rear if used for subDoes this sound correct cause thats what i read enless i misunderstood????????????????????????????Testing
Testing
Testing -
ya bud i just found that out today myself... last year's model (3-4-00 insted of 3-5-00 i think) only had 1 out. i hadn't known that they stepped up the quality this year... just found out today when the guy i worked with was tellin a customer about it and he told me about the improvements of this years line over last.
dual 2's will do ya fine... the 7400/7500 is still a better deck but the 3500 aint too shabby, no doubt
if it has dual preouts then youll be good...i said it had one because www.carmedia1.com said it had one
-Cody -
hi dudes
is there any pionner single cd player which can read WMA / MP3 / CDRW / CDR / CD with a cheap price???? less than USD 300
if any .....
and also the pionner single cd player which can read WMA / MP3 / CDRW / CDR / CD / VCD....with a cheap price ????
qoute me the price and where to get it if possible...
rdg,
loosemanTesting
Testing
Testing -
yo mtxescape....
do you have any picture of your car ??????
i would like to see it....... with all the I .C.E installed in it
rdg,
loosemanªTesting
Testing
Testing
