Kitchen is getting there
VR3
VR3 Posts: 28,585
edited November 2009 in The Clubhouse
Except for some outlet holes I patched
I still have to sand them down a little more.... once that is done - caulk up the seams around those parts..
Clean up the mess in the bottom cabinets - slap some primer on the walls and floors around the bottom cabs - then on the bottom cabs - then lay down the semi gloss on the bottom cabinets --- finish them up - mount the counter tops - mount the sink, plumbing - all the electrical related to the things going in the cabinets ---
Primer the rest of the room, paint it up - make some doors for the cabinets and utility closet - mount the hardware, put down a floor...
DONE!
Estimated time - 2-3 weeks. Shooting for two!
Post edited by VR3 on
  • audiobliss
    audiobliss Posts: 12,518
    So basically...you haven't actually done anything in the kitchen yet? :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    VR3 Posts: 28,585
    unfortunately I have done alot and I wasted a week stripping paint.
    But so far --
    I pulled up three layers of flooring, ripped out cabinets, sprayed popcorn ceiling covering in the utility closet, reframed all of the windows and door frames, built new top an bottom cabinets, skim coated the front wall - coated the other walls - patched the other areas. Rebuilt the floor where termite damage was found... Russ ran new wiring.
    Alot*** had to be done in the kitchen and unfortunately alot of time was wasted trying to work around things that were there and then decided to just start fresh..
    Keep in mind per room - I am using on average 36 pounds of joint compound and around 20+ tubes of caulk and 20+ tubes of liquid nail.
    These rooms are sealed up tighter than most new houses I would guess.
    But the next few weeks will fly by and will probably happen alot faster than I think.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Dude you have been super crazy working on this! I applaud you for your motivation/skill to start/finish your reno :) Can't wait to see some more pic's, don't be shy :D
    Have a frosty, you deserve it :)
    Cheer's!
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • exalted512
    exalted512 Posts: 10,735
    pics or it didnt happen
    VR3 Posts: 28,585
    ahhh - worked for a good 8 hours today... put down 3 gallons of Behr primer. Behr primer kills KILLZ primer anyday. I will never use that **** again.
    Anyways - four coats on the walls, one on the ceiling and a little bit on the trim. Bottom cabinets have a final coat of primer rolled on them - just need to brush it in.
    Once I get the entire room white as pearl - lol - I will put the bottom cabinets with the actual color and mount the counter...
    Room may go alot faster than expected - it is the sink that will be the hold up I am sure.
    Estimated gallons to do the entire room is 6. This includes doing the walls, cabinets, trim, floor, ceiling, utility closet.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    Per room? Are you remodeling a house, or building a bomb shelter?:eek:
    VR3 Posts: 28,585
    Funny you should use the term Bomb Shelter - Russ gives me **** about it all the time. Hehe
    Here are some current pics as of about 2 hours ago! ha
    treitz3 Posts: 18,988
    I really need to get my **** up there.
    VR3 Posts: 28,585
    hehe
    Is that a shot at my patch work?
    Check out that wall behind the cabinets Tom - maybe hard to tell by the pics - but this is what it looked like before...
    No, I ain't crackin' on your work. It's just that I could have gotten you there with much less work. Still can.
    VR3 Posts: 28,585
    For sure for sure.
    I will welcome any and all help - that is for sure.
    There is MUCH to be done, that is for sure*
    It looks like I might have some time this weekend. You bring the sweet ladies and the beer.....I'll bring the knowledge and the tools.
    You do live in a safe neighborhood, don't you? I wouldn't want all the prostitutes and single/married women chasing after me once they discover I'm there. That stuff gets old after a while and it wastes gas.
    VR3 Posts: 28,585
    Oh ****.
    You and Lightman there at th same time.
    I can't buy alcohol yet -- but I can supply you with the $$$ to buy some if you like... lol
    Hmmmm - that would be awesome. We could probally have that room painted by the end of this weekend eh?
    Ill buy the paint.
    Sounds like a plan.
    Sounds like a plan.
    ......Stan. Don't mean to be Coy Roy. Just hop on the bus Gus..........
    :D
  • audiobliss
    ...and set yourself free...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • lightman1
    lightman1 Posts: 10,788
    Oh ****.
    Ill buy the paint.
    Sounds like a plan.
    In for Saturday. Tom, I'll bring ya some speakers to listen to until you get yours back. Trey...looking good bud. If we can get the painting done, I'll go ahead and trim out the recepts and appliances. Get it knocked out and move on to the back of the house.
    Can Ya Dig It??!!
    VR3 Posts: 28,585
    Unfortunately for me - I only slept 2 hours last night. I am doing all I can NOT to fall asleep to get back on a normal schedule. So no work for me tonight.... :(
    Pick up on that stuff tomorrow.
  • Rivrrat
    Rivrrat Posts: 2,101
    Good luck.
    I've done a "strip out to the studs" kitchen remodel, and it's a lot of work.
    My equipment sig felt inadequate and deleted itself.
    Hey Russ, you ready to do some damage? I'm pumped. I'm also ready with the sledgehammer buddy! :D
  • lightman1
    treitz3 wrote: »
    10-4 good buddy!!!! See ya in the morning. The back of the house is getting demolished tomorrow..... pics to follow.....
    VR3 Posts: 28,585
    I am very scared as to what is going to happen tomorrow...
    Keep in mind - no demo in the kitchen, period!!! Just paint... LOL
    The bedrooms can be stripped down to the studs - 100%. Maybe the hallway... maybe.
    But kitchen is a paint only zone! :)
    VR3 Posts: 28,585
    Here is the patch i did on the ceiling where the old light use to be ---
    I cut out a square in the sheetrock - braced around the hole, mounted new sheetrock - took joint compound smoothed it to match the rest of the ceiling -- took popcorn "spackle" - filled it in and applied pressure evenly to the fill while quickly releasing the puddy knife to give it spikes and blended it in.
    It is not perfect - little more spikey than the rest of the ceiling but... I can more than live with it considering a light will be mounted directly beside to draw even more attention from it.
    Oh yeah and Russ -- the metal clips I found -- they mounted the old light with SHEETROCK ANCHORS... wowzers
    Russ, get a new phone.
    Trey, be afraid. Be VERY afraid.
    VR3 Posts: 28,585
    Man you guys can really down some alcohol... a trash bag full of cans - wowzers...
    Bottom cabinets are painted - ceiling is painted...
    Probably going to try to mount the counter tomorrow - if not, start painting the walls...
    VR3 Posts: 28,585
    update
  • ben62670
    ben62670 Posts: 15,969
    Looking good Bro. Next mini NC fest at your place?
    Ben
    VR3 Posts: 28,585
    possibly once the inside of the house is done
  • engtaz
    engtaz Posts: 7,663
    Looking good. Thanks for the update photos.
    engtaz
  • lightman1
    Tell 'em about the cage matches in the backyard, Trey.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    cool beans
    I am officially designating your place as the
    Taj Ma Trey...........
    ok best I could come up with on the fly........
    RT1
