4k sf luxury condo HELP ME DESIGN ultimate in-wall multi-room rig
trans am
trans am Posts: 91
edited November 2009 in Speakers
Hi, its been a while since ive been on here but my boss purchased a apt for retirement in florida and hes letting me do the a/v rig. I am basically starting from scratch. I personaly have polk LSI ,VM and rtiA series, and velodyne at home. I'm looking to make his apt sound amazing for his retirement the contractors are working on the renovating atm so its the perfect time to start looking for audio components. If you know of good deals that is key. bang for buck is my quest here. I want any recommendations as far as preamps poweramps, number of speakers. will I need a sub? all the way to wall switched sliders and receiver controllers/in wall only. I can upload a link to the layout if it will help you better. He got raped on the AV in his apt in NY. the subcontractors took advantage of him and although it sounds good I think with your help I can make a multi room rig thats 10x better and costs 10x less. Ive never done any inwall multi room setups before so i really need your suggestions. basically everything from the preamp to the wall controllers and in between. Lets build the ultimate palm beach retirement home sound system!
___EDIT________
I just read this post I made and it looks really stupid but maybe if I pick an amp out and we just build from there is will help make things easier. What about this one? http://www.accessories4less.com/make-a-store/item/MARMMAVKIT/Marantz/Av8003-A/v-Preamp-Mm8003-Powered-Amplifier-Kit/1.html align.center_height.300_vspace.5_width.260_modified.1237296489.2522.MARMMAVKIT.jpg
Adcom GFP-750
Adcom GFA-555II
Monitor Audio silver RX2
NAD T585 SACD
Technics sl-1200mk2 / ortofon m2 blue (signal cable/ Eichmann mod / Sumiko HS-12 Headshell
Jolida JD9 II / Mulllard Tubes
SignalCable Ultra speaker cables
SignalCable Analog 2 IC's
"ROMANCE WITHOUT FINANCE IS A DAMN NUANCE CAN YOU DIG I???"
Post edited by trans am on
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Polk make's great in-wall's and you should be able to find TONNE's of thing's at http://www.parts-express.com/home.cfm Check out http://emotiva.com/shop/cart.php for good gear at a great price with 5yr warranty. http://www.monoprice.com/home/index.asp also carries many thing's for great price's :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • apphd
    apphd Posts: 1,514
    How many rooms are you planning? Critical listening in all? Will one be a dedicated HT, or a casual/combo use room? How big are the rooms? Do you need good bass in each room? Do you need to have the rooms doing mutiple sources at the same time?
