Seeking Restoration/Clean-up Advice...
rallison
rallison Posts: 17
edited January 2010 in Vintage Speakers
I am the original owner of a pair of Polk Monitor Series Model 10A speakers, and while they're in darn good condition for their age (bought 1982) and sound as good as new to me, they do have some minor appearance issues. Finding this forum has inspired me to try to bring them back up to snuff. I'd like to get other Polk enthusiast's guidance on how to fix up a few items:
1. The infamous "Furniture Grade" walnut vinyl veneer is a bit grimy. In your experience, the best cleaner for it would be...?
2. The vinyl veneer on one of them is also peeling a bit at the very bottom edge of one side. The best way to re-glue would be...?
3. The 'tacky' surfaces of the drivers & PR, plus the silk dome of the Peerless tweeter, all have some light dust and/or some pet hair on them. The best way to get dust and hair off of them without damage would be...?
4. The rubber surrounds for the drivers and PR are fine--no cracking or crazing--but should I be treating them with anything to keep them flexing for another 27 years?
5. Finally, the grille cloth has 'pilled' near the edges from legs and pets rubbing against them. Can I get rid of the pilling without replacing the cloth & if so, how? OR, if it's easier just to replace, is the same cloth still sold somewhere?
Your experience and ideas are welcome--thanks in advance!
Post edited by rallison on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited November 2009
    Welcome to Club Polk!
    Answer to #3. Windex :D Just don't use it on the tweeters!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    mhardy6647 Posts: 35,033
    One could consider stripping off the charming vinyl and resurfacing with real veneer...
    I'm just sayin'...
    1. Windex does work well.
    2. I'd say white glue; tape or clamp while it dries (longer is better).
    3. if it ain't broke...
    4. no care needed AFAIK
    5. Yes replacement grille cloth that is similar is available. check www.partsexpress.com
    It is also said that JoAnn Fabrics has a black polyester material that is suitable for use as grille cloth (and probably cheaper than The Real Thing). Funny, the pulls on my grilles are from cats scratching not just rubbing :-|
  • rallison
    rallison Posts: 17
    kawizx9r wrote: »
    Thanks--happy to be here! This place is awe inspiring for an old Polk owner like me.
  • rallison
    rallison Posts: 17
    I'm just sayin'...
    Perfect! I really appreciate the thorough and prompt reply. I'll only note that if I had ever seen the cat scratching the grilles, it never would have lived to be 17. ;)
    Anyone tried using one of those electric 'sweater shavers' on worn grilles? Or would it just tear it up even more?
  • ben62670
    ben62670 Posts: 15,969
    Welcome to Club Polk. As for the sweater shavers I would only try it planning on replacing them.
    Ben
    Ben
  • rabrew1953
    rabrew1953 Posts: 13
    I've been using Old English on my 10b's for years and after 23 years people can't believe they still look new. Pledge also works well on the cabinets. I used Marine Goop to glue the peel backs.
    2 Channel only
    Sony BDP-57 (used for SACD only)
    Music Hall 25.2 integrated
    Ipod Nano 5th Gen
    Polk Monitor 10b's (modded & w/ RDO-194's)
    Frank's Ipod mini cable, Signal II IC's, & Power Cord
    Canare 4s11
  • rallison
    rallison Posts: 17
    rabrew1953 wrote: »
    Thanks - Are you using the Old English/Pledge on wood or vinyl veneer?
  • zarrdoss
    zarrdoss Posts: 2,562
    A sweater shaver does not work but a regular shaver for sideburns and stuff does great.
  • rallison
    rallison Posts: 17
    ben62670 wrote: »
    Ben
    Thanks for the kind reception--yeah, I figured I might try it only if prepared to replace. I'd have to look at possible replacement fabric first, because I'd want it to look as original as possible. Now that I'm retro, I like the full retro look...
  • rallison
    rallison Posts: 17
    zarrdoss wrote: »
    Really? 'Cause I do have a trimmer... I might just try that if you've had luck with it.
    F1nut Posts: 51,782
    1. Windex
    2. White glue, 5 minute epoxy, etc.
    3. Windex applied to a clean cotton cloth (do not spray it on the drivers) and wipe in a circular motion.
    4. While you're cleaning the cones, the Windex will do a very nice job of cleaning the surrounds. Do not apply anything else to them.
    5. A straight edge razor kind of works. Be very careful.
    I strongly recommend that you do not apply Old Engish or Pledge...nasty stuff.
  • rallison
    rallison Posts: 17
    1. Windex
    Most excellent. Except for the razor; I'm a bleeder. But seriously, thanks.
  • ben62670
    F1nut is our resident wood guru;)
    Where are you located?
    Ben
    Ben
  • rallison
    rallison Posts: 17
    ben62670 wrote: »
    Ben
    I'm in Western PA, a bit North of Pittsburgh. Why, is there a party? :D
  • ben62670
    Not yet:) It is good to have your general location showing. There are many a hospitable Polkie here. I have made many friends for life:)
    Take care.
    Ben
    Ben
  • rallison
    rallison Posts: 17
    ben62670 wrote: »
    Take care.
    Ben
    Fair enough...
  • rallison
    rallison Posts: 17
    Thanks kawizx9r, mhardy6647, ben62670, rabrew1953, zarrdoss, and F1nut! The Windex did a pretty good job on the cabinets, cones, and surrounds; and I used a trimmer to get rid of the big 'pills'. All that's left to do is glue down the loose veneer at the bottom, and they'll be in great shape. I really appreciate all your help.
    I spent a couple hours just dipping in an out of my music collection and just really appreciating the M10's great sound. Time to build some stands, I guess, so the veneer doesn't end up getting peeled away again.
    Once again, thanks!
  • gdb
    gdb Posts: 6,012
    Now ALL you need to do is........upgrade the crossovers, JB Weld the magnets on the 6.5" drivers, replace the silver dome tweeters with RDOs...and you're good to go !!:D
  • BB3
    BB3 Posts: 297
    Welcome to the Forum, rallison. I'm glad to hear everything turned out good on your speaker cleanup.
    Not sure how far away you are from the "North Hills" but you should stop by VintageHiFi down on Babcock Blvd. sometime for some great music listening and a few cold brews.
    A few of us "Pittsburgh Audio" guys and gals will collaborate there on Saturday nights just to chill and hang out.
    You can also check out the stores website for reference. : www.vintagehifipgh.com
    Take care rallison, welcome again to the Forum, and please let me know if you have any questions.
    Bill(BB3)
    Sony 52in.XBR6
    Sony 32in.XBR6
    Anthem AVM50V
    Anthem PRE-2L
    Sonic Frontiers SFCD-1
    Carver C-9
    Carver C-19 PreAmp
    Carver C-16 PreAmp
    2-Carver Silver 7-T's
    4-Carver TFM55's
    2-Carver TFM35's
    1-Carver TFM25
    Carver 490T
    Denon DCD1560
    Sony BDP-S350
    Sony PS3
    Nintendo Wii
    Panasonic DMK23DVR
    Speakers :
    PolkAudio SDA-SRS
    PolkAudio SDA-SRS 1.2TL
    PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
    PolkAudio RTA-15TL
    PolkAudio M3
    3-Velodyne F-1500's
  • rallison
    rallison Posts: 17
    BB3 wrote: »
    Bill(BB3)
    Bill/BB3,
    Oh, no you don't -- lure me in with beers and then tantalize me with those sweet glowing vintage beasts I cannot possibly afford... aaauuuugggghhhh!
    Actually I may just take you up on it, and thanks for the kind welcome.
    Regards,
    --Rick
  • BB3
    BB3 Posts: 297
    hehehehe. That was funny Rick. It's just good to know people like the owner Tom(beemers417).
    He has become a good friend and an absolute genius when, or if something would ever need repaired. And yes, you are right, he does have product there for people to buy of course, but my request to you is/was purely for just us Pittsburgh area audio guys and gals to just get together and hang out. We are it seems, us audio guys a rare bunch anymore in todays times Rick.
    Tom is actually having people over on this Saturday. My wife and I however will not be able to make it due a prior engagement with another friend who is celebrating their 40th. birthday, so I'll just keep you posted as to when I'll be there next Rick. That being said, don't be afraid to go without me being there(not that you would be--haha) because there are always people just hanging out, looking to buy things, or simply there just drink good beer, or smoke a good cigar.
    I promise that you will like what you see and most importantly....you will have a good time Rick.
    Take Care And Have A Great Weekend Rick.----Sincerely, Bill
    Sony 52in.XBR6
    Sony 32in.XBR6
    Anthem AVM50V
    Anthem PRE-2L
    Carver C-9
    Carver C-19 PreAmp
    Carver C-16 PreAmp
    4-Carver TFM55's
    2-Carver TFM35's
    1-Carver TFM25
    Carver 490T
    Denon DCD1560
    Sony BDP-S350
    Sony PS3
    Nintendo Wii
    Panasonic DMK23DVR
    Speakers :
    PolkAudio SDA-SRS
    PolkAudio RTA-15TL
    PolkAudio M3
    3-Velodyne F-1500's
  • rallison
    rallison Posts: 17
    rallison wrote: »
    I already had some scrap materials left over from a previous project, so I decided to go ahead and build the original version 7/10 stands based on plans from another thread on this forum. Bought some contact paper for the base and pedestal, some t-nuts for the carpet spike mounting points, some rubber feet for hard floors, and then went at it with the circular saw. Here are a couple of pics. I'm pretty happy with the result. Of course, now I have to upgrade the rest of my system... ;)
  • seeclear
    seeclear Posts: 1,244
    So, that second picture is your finished product? Nice.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • rallison
    rallison Posts: 17
    seeclear wrote: »
    Yep. And in the third one. Thanks!
  • chriscrawford
    chriscrawford Posts: 8
    edited January 2010
    I am interested in veneering my old Monitor 10s with real wood veneer and making some stands as well. The cabinet vinyl is just too far gone to repair, anyway I like the idea of having real wood veneer. I also intend to do the same to my Bose 501 II's. Anyone tried this?
  • chriscrawford
    edited January 2010
    I'm just sayin'...
    Have you tried this? I'm very interested in doing just that.
  • rallison
    rallison Posts: 17
    edited January 2010
    My veneer was reasonable, so I didn't touch that. I did use iron-on veneer on the pedestals of the stands I built, and it works great. I think there are threads elsewhere on the forum where folks have veneered the cabinets...
  • rallison
    rallison Posts: 17
    edited January 2010
    Windex works very well, and I followed that up with Armor All on the vinyl to restore a bit of shine; once I put 'em up on stands the peeling vinyl stuck back on its own, no glue needed; after cleaning I left the cones and surrounds untreated; I decided not to replace the grill cloth after trimming the 'pills' with an electric razor.
    Hope this helps... and good luck!
    F1nut Posts: 51,782
    edited January 2010
    Never, ever use Armor All on anything......really nasty stuff that actually attracts dust, dirt and grime, but worse than that it degrades/breaks down polymers.
