Emotiva LPA-1 7 channel amp
Meeks32
I am selling my rarely used Emotiva LPA-1 amp. I bought it almost 2 years ago & its been used maybe once a month at best. I just moved into a new place & unfortunatly all my stuff must go since its not gonna be used here. Here are the spec's.
Audiophile quality seven channel multi-channel power amplifier
Discrete, dual differential class AB amplifier topology with active current sources
Six 125 watt channels of amplification (one channel configurable for two channel operation)
Massive low noise toroidal power transformer
Complementary, discrete power amplifier design incorporating high current, high speed, Toshiba power devices
Channel status indicators for standby, operate, and fault
Configurable power output as follows: 125 watts/8 ohms x 6 channels or 125 watts/8 ohms x 5 channels plus 2 x 50 watts/8 ohms x 2 channels
Completely stable into 4 ohm loads
Rated Power Output: Channels 1-5 (All Channels Driven at 0.04%THD, 120vAC/ 60HZ supply) 8 ohm: 125 watts / 4 ohm: 225 watts
Channels 6-7 (All Channels Driven at 0.05%THD, 120vAC/ 60HZ supply) 8 ohm: 50 watts / 4 ohm: 95 watts
Frequency Response: +/- 0.1 db: 20 to 20Khz, +/- 1.0 db: 10 to 100Khz
Signal to Noise Ratio: (Un-weighted): >100db
Distortion (THD, 80Khz bandwidth): Channels 1-5: <0.040, Channels 6-7: <0.052
Damping Factor: Approximately 200 into 8 ohms
Gain: Channels 1-5: 29db, Channels 6-7: 26db
Input Impedance: 47K ohm
External Trigger: 3-12 Volts DC (tip positive)
DC Offset: <1mV servo corrected
Crosstalk: >75db
Power Requirements (All Channels Driven into 8 ohms): 1500 watts @ 120 volts AC, 60hz input
Power Consumption: Standby: 4 watts, Idle: 46 watts
Fully protected from all fault conditions
Soft start circuitry
External trigger turn on
Soft touch power switch
5RU chassis w/ solid milled aluminum faceplate
IEC power inlet, 120/230 VAC configurable
17 W x 7.75 H x 19 D
Weight - 63 lbs.
Im asking $400 & I live in orlando so local pickup is prefered but if you want to pay for shipping then we can see what it would be to have it shipped to you. Its pretty heavy.
Crosstalk: >75db
Weight - 63 lbs.
