Emotiva XPA-2 compared to sunfire
Fernando1
Fernando1 Posts: 47
edited November 2009 in Electronics
I know this is a stupid question and I probbaly know what the response or preference will be. But I have to ask
How does the Emotiva XPA-2 amp compare with the sunfire amps?
Fernando
Post edited by Fernando1 on
  • kawizx9r
    kawizx9r Posts: 5,150
    LOL
    Have heard nothing but great things about Sunfires.
    What speakers will be hooked up to this amp and what's your pre/pro you're using now?
    Also, have you considered throwing Adcom in the mix? How much are you looking to spend....
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Bernal
    Bernal Posts: 991
  • megasat16
    megasat16 Posts: 3,521
    McIntosh and SunFire are ones of the good solid amplifiers. I wouldn't call both of them Best Amplifiers and no discussion....There are literally tens of other amplifiers manufacturer that will put both of them into shame. However, I believe higher end McIntosh amps are pushing closer to Best Amp Category!
    I admire Bob Carver creations and am a huge fan of Carver stuff. SunFire is a very good and solid amp but it all depends on how far you've traveled the audio journey to call it Best.
    All depends on what you wanted to believe in.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • megasat16
    Fernando1, let your ears be a judge of what you prefer between SunFire or EMOTIVA. There are goods and bads to both of them. You'll need to do more research on this topics and use "Search" to find older threads about SunFire and EMOTIVA comparison.
  • thuffman03
    thuffman03 Posts: 1,325
    I would stick with Sunfire. They have a very good rep and have been around for a long time. I am not knocking Emotiva, but if I had $800 and had the choice between a XPA-2 and a Sunfire 300x2 I would buy the Sunfire.
    Oh, wait....I just did that. I bought a Sunfire 300x2 last week. I should have it this week some time.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • vc69
    vc69 Posts: 2,500
    thuffman03 wrote: »
    <snip>
    So... you like Carver/Sunfire products?
    I couldn't really tell where you might land on the topic. I mean, not from your sig or anything. ;)
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • concealer404
    concealer404 Posts: 7,440
    I heard he likes Sunfire TrueSubs, too... :D
  • gelinas
    gelinas Posts: 226
    Fernando1 wrote: »
    Fernando
    I've never heard either one in person, but there is no comparison in terms of price. For the money I think the emo is really worth a shot...
  • thuffman03
    If some one is going to ask for an opion I am going to give them mine.
    I know I say a lot of the same but I found that I like the sound that Carver and Sunfire make over other equipment in the same price range.
  • vc69
    vc69 Posts: 2,500
    thuffman03 wrote: »
    Same here. :cool:
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • concealer404
    thuffman03 wrote: »
    We're just playing with ya. ;)
  • BlueFox
    BlueFox Posts: 15,251
    Sunfire uses Carver’s innovative power supply technology to only draw power when it is needed. This allows the amp to produce large amounts of clean power while running cool, and drawing very little amperage from the circuit. I suspect, but do not know, that the Emo is more traditional in design.
  • vc69
    vc69 Posts: 2,500
    BlueFox wrote: »
    It is. Torroidal transformer and caps. Meh.
    I have a 20 year old Carver that still sounds good. Not as linear as it must have been in days of yore, but good. Also, I would bet the resale value of the Carver/Sunfire might be a little better.
    /.02
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
    heiney9 Posts: 25,440
    Bernal wrote: »
    LOL- Hardly, but I understand that IS YOUR OPINION.
    I would choose Sunfire over Emo, but I'm really not that impressed with Sunfire either., IMO...........of course.
    BlueFox wrote: »
    Actually I feel the "innovative power supply" is the achillies heal of most Carver gear. But then I'm a traditionalist and prefer a beefy power supply and single ended class A topology. Never cared for switching rail power supplies.
    I always thought the STASIS topology Nelson developed at Threshold was pretty cool as well as the optical biasing.........but of course those were abandoned and are no longer cutting edge.
    IMO, of course.................YMMV and there are lots and lots of designs out there they all have their pluses and minuses.
  • wetcoast
    wetcoast Posts: 64
    thuffman03 wrote: »
    Around for a long time but how much longer?
    http://www.carveraudio.com/phpBB3/viewtopic.php?f=20&t=10407
    Speakers: Polk LSi 25, LSiC, LSiFX
    Sub: Maelstrom X 18" DIY
    Amps: Sunfire Sig Seven, Behringer EP-4000
    Processor: Integra DHC-80.1
    Monitor: Sharp LC 60E77UN
    Sources: Motorola DCT-6416, PS3 Slim 250GB, Wii
    Filter: APC S15
  • Bernal
    Bernal Posts: 991
    Sunfire" and "Mcintosh" are best-in amplifier.
    Today I use Sunfire
    I am awaiting an Mcintosh.
    http://www.mcintoshlabs.com/products...Amplifiers.asp
    http://www.sunfire.com/productdetail.asp?id=3
    01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    02) SUNFIRE Grand Signature - Bob Carver's:D
    03) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    04) OPPO BDP-83 Blu-ray Disc Player w/SACD & DVD-Audio / DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    05) HITACHI P55T501. 55" HD1080 Plasma HDTV
    06) POLKAUDIO LSiC (Center speaker)
    07) POLKAUDIO LSi15 LEFT (Front speaker)
    08) POLKAUDIO LSi15 RIGHT (Front speaker)
    09) POLKAUDIO LSif/x LEFT (Surround speaker)
    10) POLKAUDIO LSif/x RIGHT (Surround speaker)
    11) VELODYNE OPTIMUN 12" (High Output Digital EQ SubWoofer 2400W/1200WRMS)
    Bernal wrote: »
    Today I use Sunfire
    See post #15
  • dorokusai
    dorokusai Posts: 25,576
    I never found a piece of Sunfire or McIntosh that was worth keeping for all that long.
  • Bernal
    Bernal Posts: 991
    heiney9 wrote: »
    See post #15
    My ear is the best judge. Sunfire satisfies me. Thanks;)
  • Bernal
    Bernal Posts: 991
    heiney9 wrote: »
    See post #15
    F1nut Posts: 51,783
    Bernal wrote: »
    There is no best. Knowledgeable folks already know that.
    Bernal wrote: »
    Glad you're happy.............the way you posted made it sound like if we didn't own one or the other we didn't have the BEST :)
  • Bernal
    Bernal Posts: 991
    heiney9 wrote: »
    Thanks;)
  • Monster Jam
    Monster Jam Posts: 919
    Ever noticed the phenomena of how a complete noob comes to Club Polk, asks two months worth of torrential noob questions, and suddenly becomes an expert in all things audio?
    Just sayin'....
    Do you hear that buzzing noise? :confused:
  • Hawkeye
    Hawkeye Posts: 1,313
    Bernal wrote: »
    Wow, that is a pretty strong statement. I like the McIntosh sound so it may be the best for me and my room but I'd never make such a broad statement as that.
    Some folks like them, some don't. The bottom line is there is no "best" amp out there in my opinion.
    Gordon
    By the way, which amp are you getting?
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
    nooshinjohn Posts: 25,928
    xcapri79 wrote: »
    Best in audio is usually a matter of opinion, isn't it?
    Where does the two channel Rotel RMB-1572 with its Class D ICE amps fit into this?
    That is the next amp I'm considering.
    I do not know where that amp fits into the the "Best" list, but I am certain that it is better than a Bose Wave Radio:D
