Speaker Levels??
pm8546
pm8546 Posts: 14
edited November 2009 in Speakers
Any rule of thumb for the main speakers and center speaker level adjustment,
or do you adjust to what sounds good to your ears.
Thanks for the help...
Post edited by pm8546 on
    treitz3 Posts: 19,992
    Trust your ears. They do not lie.
  • GZ
    GZ Posts: 343
    Hearing is believing. My Pioneer Elite has automatic speaker set up. I ran it and then tweaked it to what sounded to me.
  • danz1906
    danz1906 Posts: 5,144
    GZ wrote: »
    Agreed,Run the set-up then fine tune it to your taste.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • pm8546
    pm8546 Posts: 14
    Thanks for your insight, I will tweak it a little then enjoy.
  • McLoki
    McLoki Posts: 5,231
    I set all speakers so it is the same volume with an SPL meter. The only speaker level I adjust to taste from there is the sub.
    For some movies I may adjust the center channel up a notch or two - but by default - the center is the same level as the fronts and surrounds.
    You really want your fronts and rear speakers adjusted as close in volume to each other as possible. (and don't be tempted to move it so you hear the surrounds more) If they are not the same, things just won't sound right as they pan from the front to the back (or vice versa).
    Michael
  • dorokusai
    dorokusai Posts: 25,576
    GZ wrote: »
    AMEN.
    Even with an SPL meter I run my surrounds and subwoofer hotter than the rest.
  • danz1906
    pm8546 wrote: »
    Welcome to the Club!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
