Infinity Basslink not working
neokeelo
I am having trouble to say the least with my used Infinity Basslink I purchased a few days ago. I finally got it hooked up last night. I got a good clean connection to the battery, drilled two small holes to the chasis of my Toyota Corrola and grounded it. I have it hooked up correctly to the remote output on the receiver. When I turn on my receiver it either comes on but soon starts thumping. When I tilt the speaker or lay it down on its side or tap the side of it, It responds with a constant thumping sound. Even sitting upright it sometimes thumps randomly and the green servo light comes on (which kills the music). It stops and plays for a minute but then randomly thumps again and the green "servo" light comes on again. Before I bought it I demoed it so I know it worked then at least.
It seems to me it is something internal that is touching or not connected correctly. Has this ever happened to you when you had it? I'm reading about it online now try to figure out if i should take it apart. Could anything be cause this in the way i have it hooked, up? Just wondering if you have any ideas.
Thanks for any help you can give me.
My System
Pre/Pro - Integra DTR 40.2
Amplifier -Parasound 2205a
Paradigm Studio 60s V5 Mains
Paradigm Studio 590 V5 Center
Paradigm 20s - rear ( Wanted)
SUB - SVS PB12-NSD
LG PK250 60inch Plasma
SUB - SVS PB12-NSD
Post edited by neokeelo on
Thats a common problem with those things. Send it back if you can..
i bought it used for $80 on craiglist, he let me listen to it, sounded great when he had it hooked up..My System
SUB - SVS PB12-NSD
LG PK250 60inch Plasma -
Did you hook it up the same way he did I.E. rca plugs or universal interface wires?
Yes, Im using RCA low level output from my recevier.My System
SUB - SVS PB12-NSD
Double check your ground connection, and make sure it is as short as possible. I have had this problem because of a bad ground/too long of a ground. If all you did for a ground is drill a hole, pull the screw back out and bare the metal around the hole. Good luck, and let us know what happens
Later,
dude -
Later,
dude -
Ok, good thats a good price. What size power wire did you run?
Monster Cable 4AWG. It comes on for a few seconds if i don't move it at all and sounds good, so i know its not totally broken. I will try to troubleshoot it this weekend. Its dark when i get off work now at 5:00
One thing I know for sure, if I plug in the wire remote control it pops immediately and the green servo light comes one.My System
SUB - SVS PB12-NSD
There is a switch that selects the type of turn on. Signal from speakers or input and standard 12 volt from aftermarket headunit. Make sure you have selected the right one..
It is set to the correct setting, i check it.My System
SUB - SVS PB12-NSD
Also double check all the connection points for your power wire, make sure they are all tight.
Sorry for the double post. my internet is stupid slow internet.
