Connection from Onkyo TX-SR805 to Emotiva XPA-5
lloyd2583
Everyone has been great and thanks again!
Below is my situation:
Front: LSI-15's
SRS: LSI-FX's
Center: LSI C
Sub: DSWPrO600
I will be receiving the speakers next week as upgrade to my polk audio M40's etc. Obvious reason for need of amplifier.
So, what connections should I order for connecting my receiver to the Emotiva XPA-5??? I am a bit confused and about what I actually need as far as type and balanced versus unbalanced.
Your help would be appreciated!!!!!
Front: LSI-15's
SRS: LSI-FX's
Center: LSI C
Sub: DSWPrO600
_____________________________________________
Main System
Front: LSI 15's
Center: LSI C
Rear: LSI FX's
Sub: DSWPRO-600
Receiver: Onkyo TX SR-805
AMP: Emotiva XPA-5
Main System
Front: LSI 15's
Center: LSI C
Rear: LSI FX's
Sub: DSWPRO-600
AMP: Emotiva XPA-5
Post edited by lloyd2583 on
RCA wires if the amp is just a 2 channel amp than all you need is one set of rcas. They go from your pre outputs of your receiver to your new amp inputs.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I do not think the Onk has balanced outs, so you can forget those.
Basically you need RCA style patch cords or inter connects (IC)
something like this from Monoprice or Bluejean or many other sources.
Connect the pre outs from the Onk to the inputs on the amp, then speaker wire from the amp to your speakers. -
Just pick up 3 sets (also known as Analog Interconnects) for about $6 total and leave one wire unconnected.
Here's a link. Just search the site for different lengths if you need them.
You can look into upgrading your IC's later--this will get you started. It's what I did and can't fault them for anything. I've since bought upgraded IC's but I haven't had the chance to put them in yet, and I'm not suffering.
Nice AVR/amp combo by the wayand Welcome to Club Polk.
Pool: Atrium 60's/45's -
Appreciate the assistance! Club Polk is the best!!_____________________________________________
Main System
Front: LSI 15's
Center: LSI C
Rear: LSI FX's
Sub: DSWPRO-600
AMP: Emotiva XPA-5 -
I'm using Emotiva's x-series RCA's to connect my stuff and think they are great!Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
