Can I run this with one amp?
mx505
mx505 Posts: 6
edited November 2009 in Car Audio & Electronics
I'm putting a small system in my f150 crew cab. for the front I got momo 6x8 coaxials and the rear 6x8 DBs. I have a 10' memphis low profile sub. Can I run all 5 off a 500.4 or 200.4? I'm trying to stick to a small budget
Post edited by mx505 on
  • chu
    chu Posts: 178
    edited October 2009
    no, unless you are getting rid of the rears (which you should). If you did that; you can run the momo upfront and the sub in the back, 2 channels per component and 2 channel bridge for your sub with a 500.4. You could probably get away with 200.4 if I know what your sub specs are. It maybe a bit underpowered in bridge mode, but more power is generally better.
  • Installer4life
    Installer4life Posts: 256
    Run the rears off the headunit for fill only. use the 4 channel amp to run the momos and the sub. you can run all 4 6x8's off the front channels of a 4 channel amp if you want the volume from the rears.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Try the 5 channel alpine amp, very small, good clean power all for not a bad price.
    Personally I never liked rear speakers for listening to stereo audio.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
