Psw140
Zoomzilla
Ok, stupid question. I am getting a new reciever that is 7.2. Can I run 2 cables from the reciever to my PSW140? Or does it not work that way. My sub as a L and R, so I was wondering if it would mess it up if I ran more than 1 sub cable to it.
Post edited by Zoomzilla on
it should be the same output on both sub outs (mono) from your Arv and should not be a problem. If ANY doubt use one with a "Y" adapter on the end to go into left and right on your sub. Does your sub not have a LFE in?
Yes it has LFE, but it has L and R, so I don't know if using the Y cable would serve the same as 2 Sub cables.
