How to tell if an amp is common ground?
dpowell
dpowell Posts: 3,081
edited October 2009 in Electronics
Since I am setting up the office rig to be a place where I can demo different speakers, I want to make sure that the external power amps I buy are common ground so that I can power SDA speakers if I have the opportunity to grab a pair. Is there a list of common ground amps that anyone has compiled or alternatively, how do I find out if an amp is common ground?
Post edited by dpowell on
    F1nut Posts: 52,043
    edited October 2009
    Do you have a VOM?
  • dpowell
    edited October 2009
    If by VOM you mean multimeter then yes, I do have one.
  • sophie
    sophie Posts: 511
    edited October 2009
    i think you just check for continuity between the negatives on your amp with it turned off and no speakers attached.
    Payton
    Polk monitor 10B's and 5 jr's
    Adcom gfa 5500 and HK/240
    Adcom gtp 400
    Adcom gcp 600
    MusicHall MMF 2.1 TT
  • dpowell
    edited October 2009
    That's great information for testing amps I already own but what I'd like to do is identify an amp as common ground prior to purchase. Are there certain amps that have that specification? Is there a way to tell from an owner's manual?
    billbillw Posts: 7,858
    edited October 2009
    MOST amps are common ground. Non common ground is the exception. For amps that you are going to purchase, just google. Some typical signs of a non-common ground amp might be:
    a) monoblocs (obviously)
    b) described as dual mono (but usually this ends up still being common ground)
    c) have two separate power wires (like the Parasound HCA-3500)
    Searching here is always a great resource as well. With all the SDA owners around here, there is a plethora of 1st hand knowledge.
