DIY SUB, 1.25" polycarbonate enclosure??
polkanddie
polkanddie Posts: 224
edited October 2009 in DIY, Mods & Tweaks
Got my hands on some bulletproof glass, its 1.25" thick, I thought about using it for the walls of my DIY sub, thought it would be an interesting look. I had a suggestion to use it as just a window, possibly on top? The way my enclosure is designed I have enough to probably do 3-4 sides but not all of the enclosure... Any thoughts?
TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden
Post edited by polkanddie on
    billbillw Posts: 8,108
    edited October 2009
    If you go that route, do the majority in MDF and just use the plexi for a window on the top. Not the whole top, but just a window. You want all the corners and edges to be in MDF because it will glue/seal better. It might be more work than you want to do though. Since the plexi is thicker than the MDF, you'd have to double up the MDF and route back a ledge for the window to seal up against. I've seen some people do it, but its usually because they have a fancy chrome plated sub that they want to show off. In your case, with the mid-fi car sub, its nothing to really show off. I'd probably just do it all in MDF.
  • polkanddie
    edited October 2009
    Decided against it, maybe next time though. Got pics up of whats done so far...
    Onkyo tx sr 503
    SUB(DIY)
