what model are these..
kortland
kortland Posts: 15
edited October 2009 in Vintage Speakers
can someone please tell me if this is a sda model 1, or 1C?
Post edited by kortland on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2009
    SDA-1C Studio's.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • kortland
    kortland Posts: 15
    edited October 2009
    thanks.. how do you tell the difference between 1 and 1c?
  • keith allen
    keith allen Posts: 734
    edited October 2009
    tweeter placement,and I dont believe 1's came in black
  • comfortablycurt
    edited October 2009
    kortland wrote: »
    Original SDA 1's and SDA 1A's had Dimensional tweeters, which were arranged horizontally, rather then vertically, like the 1B's and 1C's.
    The 1B's and the 1C's had different style cabinets...the 1B's cabinet was all woodgrain finish, and the 1C's have cloth side panels and wood tops. The 1C Studio's(yours), had all black cabinets.
    As far as I know, there weren't any 1B Studio's.
  • george daniel
    george daniel Posts: 12,096
    edited October 2009
    Those are SDA 1C "studio version", they respond nicely to RDO replacement tweeters,, thrive on quality caps and resistors,and make sweet,sweet music with tube power.;)
  • kortland
    kortland Posts: 15
    edited October 2009
    thanks guys.. I´ll pick them up tomorrow.. I´m thinking of driving them with a denon poa 2400.. any thoughts on that..
  • kortland
    kortland Posts: 15
    edited October 2009
    .. and a denon pra1500 preamp..
    F1nut Posts: 51,774
    edited October 2009
    Make sure that it is a common ground amp. Other than that, it wouldn't be my choice, but then again, I'm not you. I hope you like the speakers.
  • kortland
    kortland Posts: 15
    edited October 2009
    thanks.. on a small budget, what would u drive them with?
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    I worked on a Denon POA before. It has relay on the outputs so I would just jumper the grounds. It is common ground, and has some A$$ to drive those SDA pretty damn good.
    Ben
    Ben
    F1nut Posts: 51,774
    edited October 2009
    How small?
    Ben, there's a difference between having a$$ and sounding good.
  • kortland
    kortland Posts: 15
    edited October 2009
    F1nut Posts: 51,774
    edited October 2009
    Yeah ok, get the Denon.
    F1nut Posts: 51,774
    edited October 2009
    I know this is more money, but......http://www.polkaudio.com/forums/showthread.php?t=89627
  • xsmi
    xsmi Posts: 1,801
    edited October 2009
    Will those dual mono designs power SDA's
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • kortland
    kortland Posts: 15
    edited October 2009
    allright.. looks interesting.. Im in sweden though.. the only aragon I can find here is the 4004Mk2.. and the guy wants $1150 for it
    I think I`ll start out with the denon.. and then upgrade in a year or so.. thanks for all the input.
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    The Denon POA series are a very sweet sounding amp. They're on my short list for my next experiment. :D
  • kortland
    kortland Posts: 15
    edited October 2009
    Just came accross a Sansui AU 9500 on the net for u$70.. should I pick it up??
  • geppy1
    geppy1 Posts: 3,076
    edited October 2009
    I Just picked up a mint pair identical to those for $350 which seemed pretty fair. Keith
