replace tweeter
avigoldstein
avigoldstein Posts: 2
edited October 2009 in Speakers
Hi. I need to replace a tweeter that is buzzing a bit on my Polk 10b. I have two questions.
1. I unscrewed it and saw that it is attached by little clamps. How does one get the cone off?
2. Where do I go to find a replacement cone? Thanks
Post edited by avigoldstein on
  • chrisfromalbany
    chrisfromalbany Posts: 41
    edited October 2009
    did you ask the Polk representative on the chat thing above?
  • danger boy
    danger boy Posts: 15,722
    edited October 2009
    avigoldstein, pretty sure you would have to replace the entire tweeter.. and since you're at it.. it would make sense to replace the tweeter in the other 10b speaker as well.
    Do you know what the model number is for the tweeter? it will say on the back of it.. most common are SL2000
    there is a replacement tweeter available from Polk Audio customer service.
    call the number and tell them you are a club Polk member for a discount on the tweeter(s).
    PolkFest 2012, who's going>?
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2009
    Do you know why the tweeter is buzzing? Is the crossover okay or did you have an amp that was overdriven?
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • avigoldstein
    edited October 2009
    Oops, sorry, guys. It's one of the drivers, not the tweeter!
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited October 2009
    thuffman03 wrote: »
    Good point, I would do a swap around to prove the bad tweeter first and if the tweeter is really bad, as dangerboy points out make sure you change them both as you don't want to mix and match old with new.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
