This is kinda ghetto, but...
Polk addict
I don't have an amp for my sub, so for a while, I just connected it up to the center channel, and had all my speakers set to large in my receiver.
This morning, I disconnected the sub, and then attached both a positive and negative input from both the left and right front channels. (There are actually four wires at the end of the sub wire instead of two.)
I really like the sound, but when I try and turn up the volume, my receiver says overload. :eek:
Is this going to go away like after the sub is being used a lot, or am I pushing too much into it?
Post edited by Polk addict on
Geez, I'm afraid that the sub driver you're running is a 4ohm sub (like most car/home subwoofers are) so you're creating instability issues with your AVR.
On another note, I wouldn't suggest keeping that setup....you're definitely going to eff something up.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Hrm... Resistors?... I really need that bass... Any suggestions on how to power it?
New sub it is then... Or full speakers... LoL...
Um... I have a question... What is a passive sub?
A passive sub does not have an onboard amplifier. Therefore, you need an amp to drive it. People often use pro amps for this as it is a lot of power for not much cash.
Good luck,
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
Maybe he should keep it that way, so when he blows up his avr he can buy something new!
Lol I guess that's a good way of thinking about it Sal.Polk addict wrote: »Um... I have a question... What is a passive sub?
Passive sub is just what was explained up above, of course not to be mistaken for a passive radiator. A passive sub has no onboard amplifier, and is powered by an external amplifier only. "Powered subs" are those with built in (plate-style) amps, which offer convenience but comes at a higher price.
Why don't you buy a powered sub or buy an amplifier to power the driver you currently have? If it's because of a short budget, we might be able to give you a good suggestion at what you should do to properly use your sub and not eff anything else up.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
If possible, yes I would like another suggestion, since yeah, I don't think I'm going to be getting any additional audio equipment from my parents besides wires...
Edit: The way it was setup, my speakers actually became mono, so I disconnected the sub from the system completely...
