lsi series advice
toeknee
any one have any suggestions as to what kind of receiver to use,wires/wiring and sub for a lsi9's lsic and lsifx,open to any suggestions,new to the forum and hobby.:o
Since you have LSI's you really need to look at exteral amps. They are extremly power hungry and need alot to get the most of them. Receivers really don't cut it.
When looking at receivers look for one that has the ability to run an external amp. -
Welcome to the forum.
I have Lsi9's, LSiFX's and a LSiC in my HT. I was using a Yamaha receiver years ago but went to separates Pre and Amp with 250WPC). Most people say 200WPC+ and I think I agree. More power is better. My sub is a SVS PB12-PLUS. All the cables (IC's and speaker cables) are from Signal Cable. Power cords are all PS Audio.
Good luck.Michael
NORTH of 60° -
Check my sig. to see my equipment. I definitely wouldn't recommend an AVR for a 5.1 LSi setup expect possibly a flagship model. Even then, it's questionable. I used an H/K 7300 to run 7's, and LSiC, and FXi4's and it ran very hot. I almost couldn't enjoy the system for fear of frying my AVR.Things work out best for those who make the best of the way things work out.-John Wooden
+1 on what has been said so far, look into the Flagship models as suggested if you are going to use just the AVR, like the Pioneer Elites or SC models. Onkyo TX-SR876, or even the new TX-NR3007, or 5007. Also Denon or HK, but I'm not too familiar with their stuff. Just the AVR alone may not be enough to power a full line of LSi's to their potential since they are 4 ohm speakers and love power. If you plan on using external amps, you can knock it down a few pegs on the AVR, but make sure it has pre-outs or you won't be able to add an external amp. Good luck.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
A lot of the AVR's are "4ohm compatible" which translates into current limiting. Get a lower powered AVR with Pre outs and the features you want, and run a solid amp. I personally like the HK sound, but too many people are turned off by the watts that HK's put out. Please keep in mind that a watt is not a watt is not a watt in the audio industry. 50 watts HK smoke 110 watts of the Yammi I had. Also if you go Pre/AVR amp combo when newer technologys come out you keep the amp, and just get a new Pre/AVR.
Ben -
Referring to your sig, maybe I missed it, but do you not run a receiver? -
Nope.
Pre-Pro: Emotiva LMC-1
Amp: Emotiva XPA-5Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
