Any way to put pc motherboard in blu ray plyer case and use blu ray powersupply,,etc?
duggy
duggy Posts: 10
I would love to build my own blu ray player.But can't get around the software issues.Could I use a PC motherboard,PC blu ray drive and vendor's software/drivers for it.Use the Blu ray player's power supply board,DAC's,front panel(lights),etc,etc,etc???
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited October 2009
    Do a search for pc case mods. I don't think it would be an ideal enclosure, but I've seen some pretty impressive uses of space. Heat will be an issue, you'll have to add ports for the keyboard, mouse, etc...
    Good luck, and welcome to CP.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    You can get an ITX mobo/PSU and a BD player/HDD from a laptop, i have seen a PC inside a whiskey bottle before lol
    IMHO after the cost of said item's and the time involved to assemble you would probably be better off just buying a player, unless you want to tinker then have at it! :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • nguyendot
    nguyendot Posts: 3,594
    edited October 2009
    I firmly doubt you'd get all that to work together. You'd have to have all the schematics and service manuals, along with the electrical inner workings of the original player.
    I'd just buy a player or get a dedicate case.
    Main Surround -
  • jinjuku
    jinjuku Posts: 1,523
    edited October 2009
    duggy wrote: »
    Highly unlikely.
    I would get something like the Pop Corn Hour Media Tank: C200
