Need Capacitor recommendation for SDA SRS
wrich22
wrich22 Posts: 36
edited October 2009 in Vintage Speakers
I have a pair of the original SDA SRS's, I have replaced all the capacitors with
Solen caps and Mils resistors per Darque Knights SDA Compendium. 3 years ago
I have now decided to upgrade to Sonic Caps. I have replaced the following
caps with Sonic's in each speaker
12.0 uF
4.4 uF
the 2-20 uF
and have eliminated the 750pF bypases
I Need to know what to do with the 92 uF and the 2- 130 uF capacitors, for an upgrade, they are currently Solen Polypropylene's with no bypasses.
Thanks , Bill
Post edited by wrich22 on
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    The Solen's are fine in that app.
    Ben
