Speaker placement
fomoco69
How much of an affect does speaker placement have on sound quality?.........such as M5's
Post edited by fomoco69 on
Sound quality? Proper location is required to obtain a good sound stage and imaging with any stereo speaker setup. It is probably the most important part of proper system set-up. Distance between speakers must be set for a proper center image & soundstage. This will depend on how far your listening position is from the speakers. There are test disks that can be used to determine proper location of the speakers. The best test to find proper speaker location I have found is on a CD: Best of Chesky Jazz & More Audiophile Tests Vol. 2. It contains a test of a sound which seems to travel around the outer edges of the room in a circle. You move the speakers until you hear the sound "travel" properly. I could notice a difference when a speaker (SDA's) was moved 1/4" or less. - In another thread I mistakenly stated this was a "clicker test" and may be on a Stereophile CD. I am getting forgetful as I get older and not used the disk in about 15 years or more. The "clicker test" is for soundstage depth.Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
Pre-amp: DBX CX1
Center: CS1000p Rear Surr.; f/x1000
Parasound HCA-1205A amp; Center & rear
Sub: SVS PB12-Ultra
DVD: Denon 3910
Tuner, FM: Onkyo Integra T-9090II
Cassette: Onkyo Integra TA-2090
VCRs: JVC HD4000U digital, HRS8000U SVHS
Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
Conditioning: Monster AVS2000, HTS5100MKII
