Making an SDA interconnect
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2010
    Thanks for taking the time to quote four different posts instead of helping someone in need.
    It's just that I just derived such huge entertainment value from what were your original words, . . .
    . . . which were precisely, "I can't be bothered . . . " . :D
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Assimilator87
    Assimilator87 Posts: 20
    edited January 2010
    It's just that I just derived huge entertainment value from what were your original words, . . . "I can't be bothered" . :D
    No worries. I probably deserve some ball busting for that line. So is it safe to disconnect and reconnect the cable while there's something playing so I can A/B the difference? I keep worrying about frying something. It may not sound like it, but these are my dream speakers and they're one of the most prized possessions of mine.
    Polk SDA 2B (Pin/Blade) - Front L/R
    Polk SDA CRS+ (Blade/Blade) - Center
    Polk Monitor 5B - Rear L/R
    Onkyo TX-SR805 - Receiver
    Carver TFM-35 - Amplifier Front L/R
    12 AWG Monoprice Speaker Wire
    Blue Jeans Cable Belden F2 HDMI
  • inspiredsports
    edited January 2010
    Assimilator87,
    I might have missed this, but did you say your SDA-2B female interconnect connections on the back of the cabinet are what they call Blade/Blade, or Pin/Blade?
    The reason I ask is that the 1987 Blade/Blade version of the SDA-2B is unique in that only the narrow blade is connected inside of the cabinet. If you have Blade/Blade, I don't think an RCA plug will fit into the narrow blade's slot.
    Greg
    NAD SS rigs w/mods
    GIK panels
  • Assimilator87
    edited January 2010
    It has the pin/blade jack.
  • inspiredsports
    edited January 2010
    Then it is correct that only the pin side needs to be connected from left to right cabinet to complete the SDA circuit if you are certain you have a common ground amp.
    All you need then is the single pin to pin connection (I was actually being half serious that a coat hanger wire between the two pin sockets really would do the trick if you could insure it didn't touch anything that would short it out :) )
    . . . is it safe to disconnect and reconnect the cable while there's something playing so I can A/B the difference? I keep worrying about frying something. It may not sound like it, but these are my dream speakers and they're one of the most prized possessions of mine.
    I've plugged and unplugged mine a few times with music on at moderate listening volumes with both my SDA-2B's and SDA SRS 2's with no apparent problems. I'm not an EE, but my take on it is that it impacts the speakers in even less than the same way as when you first turn them on with the volume turned up a bit on your preamp or receiver.
    2B's are amazing speakers, especially when modified according to "TL" guidelines you can find here at CP.
    NAD SS rigs w/mods
    GIK panels
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Yes my friend but how would it sound?
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited January 2010
    Should one attempt to replace the SDA interconnect cable of his (meaning me) Polk Audio Speaker?
    I take it I would get better imaging if I did?
    And if I did, would anyone recommend using a quality RCA cable and chassis connector to replace the current IC cable or should one use binding posts with heavy sheilded speaker cable to get the maximum imaging?
    Audio nirvana is the goal here.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • hearingimpared
    edited January 2010
    Check this thread out by DarqueKnight.
    http://www.polkaudio.com/forums/showthread.php?t=30467
    Great stuff on SDA cables.
  • PolkMaster1
    edited January 2010
    I have not read the whole article yet by DarqeKnight (but I will, love his name by the way!), with all the modifications that people have done with the SDA line to further improve the sound, one would think that Polk would have put all of these improvements into their hallmark SDA and SRS-SDA line to give it the final touches, marking them a superior speaker, which they already were at the time that they were manufacturered and are still considered a superior speaker for those of us who are experienced with the legendary Polk SDA sound.
    Are you really hearing impared as your name implies? Is it because of all that SDA listening you do? ;-)
  • hearingimpared
    edited January 2010
    To answer your first question they had to keep costs down or the price of the speakers would have been prohibitive at the time and to the target consumer.
    Yep, I have hearing lose in my right ear since I was a child but have become accustomed to it.
  • inspiredsports
    edited January 2010
    Joe, that's one experiment (coat hanger) I have not tried. :D
    I have some very special 12-gauge 19-strand Silver wire with Kapton Teflon insulation running between both sets of SDA's. And yes, after I did the listening tests, I sold both my original Polk and Polk after-market interconnect cables here in the CP for sale thread.
    NAD SS rigs w/mods
    GIK panels
