Parasound HCA 1200 II
Polksaladanni
Anybody have an opinion on this John Curl amp?
Picked up a near mint one for $250.00 From someone I know in Fla.
Spec look pretty damn good.
A little better headroom than the Adcom 555II & 5500...
The current pull scares me. Seperate curcuit from the house fuse panel...
TIA, Paul
Here's the specs:
MANUFACTURER: Parasound
MODEL #.: HCA-1200 II
SPECIFICATIONS
Continuous Power Output - Stereo
205 watts RMS x 2, 20 Hz-20 kHz, 8 Ω
315 watts RMS x 2, 20 Hz-20 kHz, 4 Ω
Continuous Power Output - Mono
625 watts RMS, 20 Hz-20 kHz, 8 Ω
Current Capacity
40 amperes continuous
57 amperes peak
Slew Rate: >130 V/µsecond
Frequency Response: 8 Hz-150 kHz, +0/-3 dB at One Watt
Total Harmonic Distortion
< 0.06% at full power>< 0.03% typical levels
IM Distortion: < 0.04%
TIM: Unmeasureable
Dynamic Headroom: 2.0dB
lnterchannel Crosstalk
> 80 dB at 1 kHz
> 63 dB at 20 kHz
Input Impedance: 42K Ohm
S/N Ratio: > 110 dB, input shorted, IHF A weighted
Damping Factor: > 600 at 20 Hz
Special Features
THX Certified by LucusFilm LTD
Massive 1kVA power transformer
60,000uf computer grade capacitors in power supply
Multiple polystyrene film bypass capacitors in power supply
Cascode Class A input stages with matched J-FET pairs
Hand picked MOSFETs in high voltage driver stage
10 pairs of 50mHz, 15 ampere bipolar output transistors
Output transistors direct couple to speakers without LRC Network
DC servo direct couple audio circuits with 3Hz roll off
Linear Tracking, instantaneous acting DC servos
High Bias Class AB operation
Gold plated metal structure RCA input jacks
Multiple temperature sensors and silver cadmium relay protection
FR-4 glass epoxy circuit boards, double sided for precision
Proprietary quick setting bias circuit obviates warmup period
Dimensions: 19" wide x 5.5" high x 13" deep
Weight 37 lbs. net
AC Power Requirements - 1000 watts
TIA, Paul
Here's the specs:
SPECIFICATIONS
Current Capacity
57 amperes peak
TIM: Unmeasureable
> 80 dB at 1 kHz
> 63 dB at 20 kHz
Special Features
Weight 37 lbs. net
Post edited by Polksaladanni on
You will be fine. Snag it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
It is snagged and shipped already.
I was just curious on the sound the Adcoms were kinda edgy at first.
But I liked the sound of the 5500. A little more warmth.
He says its not as bright/edgy as the Byston he got.
Paul -
Congrats!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Nice snag for that price.
Thanks.
He cruises' the rich folks area and finds tons of vintage stuff plus, several of his Fla friends change eq or modernize.
I would love to see pics of you Westhost DIY-Ext. XO.
Paul -
Yeah I could see that pusuit paying off at times.:)Polksaladanni wrote: »
If you mean my active xovers neither are from Rod Elliot( he's the guy behind the excellent westhost site.).The Bryston looks similar to this http://www.bryston.com/10b_m.html and is slightly modded internally.The linkwitz unit is described here.http://www.polkaudio.com/forums/showthread.php?t=79522&highlight=linkwitz+active+crossoverI would love to see pics of your Westhost DIY-Ext. XO.
PaulTesting
Testing
Testing
