DSW4000 Break-In Period
JSP61
JSP61 Posts: 4
Hey guys, I'm new to this forum. I have a question about the break-in period of the DSW MicroPRO 4000. I heard different story between 80 to 200 hours (because it supposedly has a very stiff cone).
Additionally, I would like to know if there is a specific method for breaking-in subs.
Regards,
Onkyo TX-NA5007
LSiC (Center)
LSi15 (Front)
LSi9 (Surround)
DSW MicroPRO 4000 (Sub)
Monster HTS 5100 MKII PowerCenter
Logitech Harmony 900
Panasonic TC-P50V10
Post edited by JSP61 on
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2009
    Play it loud and play it soft. Mix up the music and put in some good base cd's.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • JSP61
    JSP61 Posts: 4
    edited October 2009
    thuffman03 wrote: »
    Hey Thuffman03, thanks for your answer. :)
    How about the length of time for the break-in period?
    Additionally, I heard that putting a lot of stress (which means deep base) on the subs is not very good until they are broken in. Is this true?
    Onkyo TX-NA5007
    LSiC (Center)
    LSi15 (Front)
    LSi9 (Surround)
    Panasonic TC-P50V10
  • Ron Temple
    Ron Temple Posts: 3,212
    edited October 2009
    JSP61 wrote: »
    Nope...you may experience subjective improvements, but there's no reason to baby it. You're good to go.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2009
    Just hook it up and play it. Don't worry about breakin it in.
  • megasat16
    megasat16 Posts: 3,521
    edited October 2009
    leroyjr1 wrote: »
    Very true! It's being broken in from the time you start using it. Just hook it up and use it normally.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2009
    Press play and move on with your life.
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    Welcome to the Club!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • jimsvm
    jimsvm Posts: 307
    edited October 2009
    Just hooked my 3000 up and rocked it.No problems after a year.Can't wait to get a second. ENJOY
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
