Differences between new and "vintage" Parasound pre-amps significant?
dbaldus
dbaldus Posts: 730
edited October 2009 in Electronics
I'm considering picking up a pre-amp now that I've got a decent little 2 channel setup (see my signature) and am wondering what the differences between the older and newest Parasound pre-amps would be?
The pre-amps I am considering are:
1. Parasound PHP-850
2. Parasound New Classics 2100
I'm concerned about the differences in sound quality, NOT things such as having a remote for one but not the other. Just curious how much pre-amp technology has progressed in the 10-15 years or so between these models being produced as I can probably pick up a PHP-850 for a fraction of the price of the 2100 if the differences are minimal.
Side note: Now I just have to figure out what the hell is going on with my 2200II... :mad:
Thanks!
Derek
2-channel
Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
Post edited by dbaldus on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2009
    I wouldn't think so, but the new one I'm sure has auto turn on, where the older model most likely didn't.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    billbillw Posts: 7,794
    edited October 2009
    Well, if you can find one of the higher end preamps from Parasound (P/LD-2000, 1500, or 1100), then there is quite a difference. Those were extremely well built preamps that would cost a fortune to build today. IMHO, the HCA-2200II deserves a better preamp. The 850 is not quite up to the rest of the line. The sacrifice you make is no phono preamp (on the P/LD series), but that opens you up to some very nice stand alone phono stages.
  • dbaldus
    dbaldus Posts: 730
    edited October 2009
    billbillw wrote: »
    Well, if you can find one of the higher end preamps from Parasound (P/LD-2000, 1500, or 1100), then there is quite a difference. Those were extremely well built preamps that would cost a fortune to build today. The 850 is not quite up to the rest of the line. The sacrifice you make is no phono preamp (on the P/LD series), but that opens you up to some very nice stand alone phono stages.
    So, just to be clear, you feel that the quality of the P/LD-2000, 1500, or 1100 would be better than the New Classics 2100?
    Any idea on the differences between the PHP-850 and the New Classics 2100?
    By the way, I'm not interested in a phono stage and would be using a CD player as a source...
    Thanks again...
    Derek
    2-channel
    edited October 2009
    dbaldus wrote: »
    Thanks again...
    Derek
    Yes, much better. If you don't want/need phono, then I would definitely think about a PLD-1100. I can't really compare the 850 vs New Classic, but based on the description of the 2100, it doesn't sound like its built to the standards of the old Parasound.
    Have you seen this:
    http://www.polkaudio.com/forums/showpost.php?p=703713&postcount=459
  • disneyjoe7
    edited October 2009
    Interesting thanks for the input, learning something every day. It did surprise me what you're saying, but from Parasound.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • megasat16
    megasat16 Posts: 3,521
    edited October 2009
    billbillw wrote: »
    Very nicely built pre. I think the newer Halo P3 pre would be comparable to this in terms of sonics.
    Since a lot more pre are built with digital in mind these days, there are less analog components and even more importantly, most components are SMD and circuits are smaller. I still prefer the old Analog pre over the newer pre but Halo JC2 is very highly reviewed and praised.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    edited October 2009
    megasat16 wrote: »
    Not even close. The Halo P3 has nowhere near the build or sonic quality of that old PLD2k. The JC2 is the closest thing in the current lineup, but of course, surpasses it in both build quality and sound.
  • megasat16
    edited October 2009
    PLD2K sure is very nice preamp and you really got me interested in it. I got to listen to it one day. I always like John Curl Designs.
  • dbaldus
    dbaldus Posts: 730
    edited October 2009
    billbillw wrote: »
    Have you seen this:
    Thanks so much for the tip - I just won a PL/D 1100 on eBay for $233.67 and can't WAIT to get it home with me!
    Not a bad price, in my opinion, especially compared to the NewClassics 2100, which sounds like its a lesser pre. Now I'm just hoping that these old Parasound pre-amps were built to last and that it won't fall apart on me... ;)
    2-channel
    edited October 2009
    dbaldus wrote: »
    It is definitely built to last. You shouldn't have any problems with it. I had a ground loop problem with mine, but that was easily solved.
