SVS mix or match
gwh
I'm looking at some SVS subs on Audiogon, seller has a CS ultra and two 20-39's.
I have a 25-31 and thought about moving it to the back and running the ultra up front or buying both the 20-39's and run them in opposite corners.
Which would be the best set up?
Is the price he is asking reasonable?
I'm rolling down that way Saturday (DFW) so if anyone in the area has a CS they want to part with at a better price let me know.
http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1260693486&/SVS-CS-Ultra-Subwoofer
Thanks,
G
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
Thanks,
G
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Thanks for your opinion Ron.
I'm leaning toward picking up the ultra and moving the 25-31 to the back opposite corner.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Do you have an amp that can deliver 900w into 4ohms. The TV12 driver can take that and more. You can get by with less if you're careful. You might want to ping Ed Mullen and ask for recs.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I have an Adcom 555 with one channel biamping my lsic and the other channel running the 25-31. I could bridge the 555 and put it on the ultra and run the 25-31 off a marantz mono(180@4) that I've used before with good results.HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
