12 o'clock on an AVR
coolsax
I've seen in some previous threads not to push certain AVR past 12 oclock on the volume and I understand the terminology on an older receiver in that you don't put the volume line past the 12 oclock position when you have a volume dial, but when you're dealing with a digital display where you have no line on the volume control, what is considered 12 oclock? is it 0db or less or more?
I know you don't want to play too loud when breaking in speakers.. how loud is too loud? is it over 0db or is it closer to 90db when extended listening can start damaging your hearing? just curious I haven't had my M60's long and I don't want to damage them by playing it too loud but i'd like to know where that too loud spot is..
Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22
TV 3.1 system -
Post edited by coolsax on
Crank it 'till it Hz! lolMedia Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask -
I have had my pioneer all the way to 3+ without a problem and had it there for about 3 songs. Just listen for distortion if you hear any back it off or if you are in doubt back it off.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
