What amplifier brands sound the best
buymesome
buymesome Posts: 281
edited October 2009 in Electronics
I would like recommendations on amplifier brands that have high quality sound that you think I should be checking out on the used market
I plan on spending $300 -$500 for a 2 ch on the used market
If I decide to sell my stuff to a buddy then I will buy a new ssp and look for a 7 or 5 ch amp and be willing to spend $400 - $700
Latley I have looking at audiogon and clicking the " research this item" but its to much to take in and I think my search would be easy if you guys could give a novice like myself some recommendations beforehand
Thanks in advance for your time gents
I should add that I would prefer compatibility with electrostats and I would rather have quality vs more watts
Post edited by buymesome on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    you seek........Parasound or NAD or something better sold on the cheap from a widow or angry divorcee, do not though believe in false idols.
    RT1
    PS.....I am sure the peanut gallery will finish licking the Planters from their fingertips shortly and arrive with further anecdotes and products for your personal perusal, do the research, save the Rig.
  • george daniel
    george daniel Posts: 12,096
    edited October 2009
    For two channel small amps(read not alot of watts,but decent enough power) try the little Adcom 535,,there was one in the FM recently. good luck.
  • Big Dawg
    Big Dawg Posts: 2,005
    edited October 2009
    Do you know what speakers you'll be driving? What kinds of music do you like? How loud do you listen? How big is the room? What's are the most important aspects of music to your listening experience (for example, do you prefer slamming bass or sweet mids)?
    If you listen to any kind of rock, but especially metal, techno, rap, etc., you'll probably want big drivers and an amp with lots of clean power, like the Adcom suggested above. Also, Carver, B&K, NAD, Yamaha, etc. can all be found cheap on the used market (I think I have a few extra lying around, in fact).
    If you like more vocals (especially strong female voices), or any kind of acoustic music (like jazz), you might prefer something like a nice old Dynaco like this one: http://cgi.ebay.com/Dynaco-ST-35-Stereo-Power-Tube-Amplifier-Nice_W0QQitemZ290361951389QQcmdZViewItemQQptZVintage_Electronics_R2?hash=item439aebc49d
    I personally use a tube preamp with a solid-state amp - kind of gives me the best of all worlds (on my budget and to my ears and listening preferences).
    I've found that the best part of buying "vintage" gear is that you can try it in your own system for as long as you want, and when you find something else that you like better, you can sell the original component for about what you paid.
    Hope that didn't confuse more than help....
    Dawg
  • buymesome
    edited October 2009
    Thanks for the recommendation george I was thinking about the adcom 545 . I think concealer has one to sell but I'm thinking end of november I will buy somthing
    Hey big dawg what kind of stuff at what prices do ya have stashed away ? It would be nice to know for future refrance.
    Right now I use polk a3's borrowed from my brothers buddy who has my A5's but I plan on getting into electrostats and Ilisten to everything
  • Big Dawg
    edited October 2009
    buymesome wrote: »
    Not sure I'm selling anything anytime soon, but then again I might....
    I have a B&K ST-202 (150 WPC), a B&K ST-202+ (200 WPC) and a Carver M4.0t (375 WPC) (all WPC @ 8 ohms). Only need one, just don't yet know which one....
  • zarrdoss
    zarrdoss Posts: 2,562
    edited October 2009
    I have Rotel, Adcom, and Carver, all sound great
    nooshinjohn Posts: 25,928
    edited October 2009
    You ask a rather loaded question, but the best answer I can give is that the best sounding amps of all time are the ones that your ear likes best. I love my Sunfire, but have also had great experiences from Carver, Yamaha, Hafler, Nakamichi and Denon
  • wallstreet
    wallstreet Posts: 1,405
    edited October 2009
    The ones that sound best to your ears (and within budget) are the ones I buy.
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    buymesome wrote: »
    If you have a $300-$500 budget, i would suggest getting something a bit better than the 545, much as i'd like to help you out with it. :p
    a3s won't need a ton of power, but the electrostats will. :D
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    I like Burger King more than McDogfood when it comes to burgers, and McDogfood more for fries and chicken.
    Ben
    Ben
  • Hawkeye
    Hawkeye Posts: 1,313
    edited October 2009
    Not sure of what what you really mean by "electrostats". If a true ESL, such as Martin Logan, you're going to need an amp stable at 4Ohms. The Spire will dip to .75Ohm which may wreck havoc on some amps.
    Some recommndations of ESL users are a high current amp vice high wattage by PassLabs, B&K and of course my favorite, McIntosh! Buying an amp for an ESL takes a bit more research than buying an amp for box speakers. While any amp will work for a time, the accuracy of an ESL will quickly let you know if you made the right choice. I'd suggest:http://www.martinloganowners.com/forum/index.php as an excellant forum or source for taking the leap into an ESL.
    If you're talking about Maggies, disregard my info since I've never owned or experimented with them.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2009
    Your budget allows you quite a few amps. Carver and Adcom are very good amps. You can pick up a Carver TFM 35 for about $350 and get into a Carver TFM 45 in the mid $400's and a TFM 55 should be at the top of your budget in the low to mid $500.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • coolsax
    coolsax Posts: 1,826
    edited October 2009
    What are y'alls opinons about the Emotiva amps? They seem to push quite a bit of power for a very reasonable price brand new. they seem to review pretty well and to tell you the truth on what i've seen its hard to find a 5 channel 200wpc amp for 800 used let alone brand new. I've heard some people don't really like the look of them.. but I do so i'm more worried about quality.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2009
    From what I have seen and read, for the most part they have good quality. However, all manufacturers can have quality control issues come up.
    They are a good brand as well as any others you might look at & you won't have to rob a bank to get one. Go for it.
  • concealer404
    edited October 2009
    The build quality of the two that i've seen couldn't be faulted. VERY solid construction, and that same quality carried over to their cd player. Damn thing may as well have been made from a solid chunk of steel.
    I wasn't 100% impressed with the sound, but that's an opinion that'll vary ear by ear. :)
  • thuffman03
    edited October 2009
    I never saw one or heard one. Anyone who has one seems to like them. They also have a 30 day money back if you don't like it.
  • coolsax
    edited October 2009
    I saw that on the 30 day.. which is nice.. the 5 year warranty also is enticing as well
    Main 2ch -
    TV 3.1 system -
