DIY SUB. I got the amp, I got wood(you can laugh), opinions on whats next?
polkanddie
polkanddie Posts: 224
edited November 2009 in DIY, Mods & Tweaks
This is my amp, Just got it in a trade. Dayton HPSA500 500W Subwoofer Amplifier. I was thinking about changing it up and using a dual 2ohm woofer, either a kicker L5, Infinity Kappa, Or possibly a Polk?? Any thoughts...
TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden
Post edited by polkanddie on
«134
  • Face
    Face Posts: 14,340
    edited October 2009
    What's your budget?
    How much space do you have for an enclosure, etc...?
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    Don't think about how much 'wood' you currently have, you can and should always get more at your local Lowe's or Home Depot or any other lumber provider if you need more of it. I say this because depending on the type of driver you pick up, you might need a large/medium/small box given the drivers T/S parameters. Click the subwoofer link in my signature to get an idea of a few things you'll need along the way. The guys here at CP have been way more help to me than the other forums I've tried so look forward to that :)
    Anyway you go with it, best of luck!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Face
    Face Posts: 14,340
    edited October 2009
    I hope you're using either MDF or Baltic Birch.
  • kawizx9r
    edited October 2009
    Face wrote: »
    +1
    Almost forgot about that!
    I used MDF for mine (3/4" thick), and it was only 27 bucks for a 4' x 8' board. In fact I still have a 2' x 4' piece left (used half of it for my oversized subwoofer).
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • zingo
    zingo Posts: 11,258
    edited October 2009
    What about a Focal W cone driver? If you could find a good price on one, I feel like it would be the most accurate and musical subwoofer around.
  • Face
    Face Posts: 14,340
    edited October 2009
    zingo wrote: »
    They're nice if you don't mind paying $750 each.
  • polkanddie
    edited October 2009
    Oh wow, that would be nice. This is going to be a low budget project though...Most likely going to find a driver on ebay or CL. I am using 3/4'' mdf, Also this is going to be mainly an HT sub. Has anybody tried the whole passive radiator option before? It looks complicated... anyways, I have an old qlogic I was going to use the ports out of it, or at least the flared ends, would it be easier to just make a slot port?
    Onkyo tx sr 503
    SUB(DIY)
  • polkanddie
    edited October 2009
    Also I wanted it somewhat compact, I was thinking an 8" or 10", but definitely something that can handle a good 250 rms without a sweat.
    Onkyo tx sr 503
    SUB(DIY)
  • kawizx9r
    edited October 2009
    polkanddie wrote: »
    Like I said above, I think you're looking past a few important things. If you want the sub to work properly and give you the bass you crave, set it up right. All subs are different, and going from a slot-loaded enclosure/ported enclosure/sealed enclosure will yield different sized enclosures. It's not just building a box, putting a port/hole in it and calling it a day. Take it 1 step at a time.
    -Freddy
    P.S. My sub cost less then $240 to make, not saying its something you can do using the same box-dimensions unless you got a deal on the same driver I used. Just make sure to do it right and you'll be very pleased. I know I am :)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited October 2009
    One last thing, here you go. An enclosure volume calculator - http://www.hometheatershack.com/forums/enclosure-volume-calculator/
    Talk to someone that has WinISD as well, such software can help you find out what port lengths/diameters/etc. are needed to achieve certain frequencies given said driver/amp.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Face
    Face Posts: 14,340
    edited October 2009
  • zingo
    zingo Posts: 11,258
    edited October 2009
    Can't go wrong with Seas!
  • Face
    Face Posts: 14,340
    edited October 2009
    zingo wrote: »
    I have a pair of these that will be going into my HT soon. http://www.madisound.com/catalog/product_info.php?cPath=45_228_258&products_id=822
  • zarrdoss
    zarrdoss Posts: 2,562
    edited October 2009
    I have the same amp and paired it with a 15" 4 ohm kicker comp vr in a sealed box. it sounds great.
    http://www.polkaudio.com/forums/showthread.php?t=85249
  • polkanddie
    edited October 2009
    Ok, I was on newegg this morning, saw what looked like a deal on a 10" Polk DB series sub, guess what 270w rms and 540w max.... same as my amp. Single 4 ohm voice coil. Looks to match up perfect. It was 29.99 shipped. I dont think you can beat that.... here are the specs.... General
    Brand Polk Audio
    Model db 104
    Type Subwoofers
    Component
    Subwoofer Size 10"
    Cone Material Dynamic Balance Polymer Composite dish cone
    Surround Material Santoprene surround
    Voice Coil Single
    Voice Coil Construction 2" Diameter Double venting of the 4-layer Kapton Voice Coil
    Damper (Spider) Fire-retardant flat NOMEX Spider
    Specification
    Peak Power 540W
    RMS Power 270W
    Frequency Response 28 Hz - 200 Hz
    Sensitivity 86 dB
    Impedance 4 Ohm
    Crossover Point 37 Hz
    Thiele/Small Parameters Qms: 7.0, Qes: 0.62, Qts: 0.57, Vas: 0.85 cu. ft., Sd: 54.25 sq. in., Xmax (linear): 0.3 inch, Xmax (mechanical): 1.0 inch, Le: 1.85 mH
    Mounting Depth 6.25"
    Any suggestions about box dimensions with this info.
    amp info is ...
    High power class AB output stage
    Patented tracking downconverter power supply
    Full parametric bass EQ
    Phase reversal switch
    Advanced soft clip circuitry
    Toroidal power supply transformer
    Auto On/Off
    Power output: 273 watts RMS @ 8 ohms, 540 watts RMS @ 4 ohms
    S/N ratio: 98 dB (A weighted)
    Crossover: 30 - 200 Hz, 24 dB/octave
    Dimensions: 11-15/16" W x 11-15/16" H x 5-1/4" D...
    And I realize I may have made a booboo.... It seems I may have too small a sub...
    Onkyo tx sr 503
    SUB(DIY)
  • polkanddie
    edited October 2009
    I swear I saw 240 rms at 4 ohm on the manny.... let me go find that thing.
    Onkyo tx sr 503
    SUB(DIY)
  • polkanddie
    edited October 2009
    kawizx9r wrote: »
    Sweeeet thanks dude.
    Onkyo tx sr 503
    SUB(DIY)
  • kawizx9r
    edited October 2009
    polkanddie wrote: »
    No problem, and with WinISD + T/S parameters you posted above you'll find out exactly what type of enclosure will work out for you. It'll also give you expected frequency response/etc.
    I'm getting output down to 18hz from my DIY subwoofer :D
    -Freddy
    PS I wouldn't mind grabbing that 500 watter from you, my amp is actually a 250w rms model@4ohms not 240w.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • polkanddie
    edited October 2009
    Ok, so what does it mean when the website says rms and the manual that came with it says 273max at 8ohms and 540max at 4ohm.... thats kind of misleading if its the latter...
    Onkyo tx sr 503
    SUB(DIY)
  • kawizx9r
    edited October 2009
    polkanddie wrote: »
    It's not really misleading, those are the specs given at certain loads IE 273watts@8ohms and 540watts@4ohms. My amp is 150watts@8ohms and 250watts@4ohms.
    The max ratings will also state distortion levels/etc. and if you read more about that you'll see whats "acceptable" to state in the manual/specifications. The power actually going to your speakers isn't always a full 273@8/540@4, that's determined by the volume level you're driving them at.
    In laments terms, if the speaker being driven is a 4ohm load such as your subwoofer you purchased....your amp will see that 4ohm load and supply it the 1-540 watts (hopefully you don't turn it up that loud).
    EDIT: Btw, remember to use all your t/s parameters correctly. I read about a sub or two lost due to crazy over-excursion because the way he had his box ported or sealed.....anyway just do it right. 'Nuff said.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • polkanddie
    edited October 2009
    Qms: 7.0, Qes: 0.62, Qts: 0.57, Vas: 0.85 cu. ft., Sd: 54.25 sq. in, Ok so what does all this mean... It needs a .85 cubic foot box sealed? I think thats all I would be doing unless I use a sonotube... btw. how would I mount the subwoofer in one of those?
    Onkyo tx sr 503
    SUB(DIY)
  • kawizx9r
    edited October 2009
    Maybe Ben can chime in later in regards to the sonotube. Btw, sonotubes are usually ported enclosures, the height of the sub makes up for the lack of sq. footage it occupies while still giving you a lengthy-sized port for that deep bass.
    You ready to put in all the work to build this sucker? It's not hard at all, but there were some things that I had to do that I didn't like IE caulking my port tube in the inside and sealing everything,etc.
    Just today I covered upsome of the nail/screw holes with some wood filler. I'll take a pic of it to show you, but just goes to show I'm not done yet. Will need to cover up the rest of the holes, sand, primer, then paint+sand+paint+sand+paint and then finish it off with a clear coat or something.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited October 2009
    Here you go, big SOB.
    The lighter colored spots is where I put the wood filler in. Dreading having to take things out such as the plateamp and sub to sand things down and get it ready for paint. Who knows, it might be pushed awhile back and I'll just apply one of those laminates or something.
    Maggies right next to it :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • polkanddie
    edited October 2009
    Noice. I kinda want one to be pretty small and/or in a tube. How are you going to finish it?
    Onkyo tx sr 503
    SUB(DIY)
  • kawizx9r
    edited October 2009
    polkanddie wrote: »
    Just like the guy I met told me.....cover up the holes, sand until everythings flush and smooth then primer. Sand, then paint, sand, paint, sand some more (using higher grit paper after every coat) and paint once more. By the 3rd coat or so, I'll be using 600/800 grit sand paper just to smoothen things out if necessary. Should give me a very streamlined look. I'll only do all that if time permits and if I don't just dump the whole idea altogether. I hate not having a sub when listening to music, it's the only reason why it's put together without a finish on it :o
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • polkanddie
    edited October 2009
    I traded my Eosone rsf600's for this amp. It seems like a good deal since I couldnt sell them for the $150 I wanted for them... pretty sad huh.
    Onkyo tx sr 503
    SUB(DIY)
  • polkanddie
    edited October 2009
    I think I am going to go with a basic square sealed box with good bracing, I might up the mdf to 1" and add some carpet spikes and sometype of grill. Probably the polk one that Ive seen with this woofer..
    Onkyo tx sr 503
    SUB(DIY)
  • kawizx9r
    edited October 2009
    polkanddie wrote: »
    Take it one step at a time ;)
    Always double check all your measurements, you don't want things cut out and not lining up properly if at all. 3/4" will suffice, especially for the driver you're using but if you want 1" that'll work too. I chose not to use a grill at all, nothing beats seeing my subwoofer dance like crazy with some bassy music.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Face
    Face Posts: 14,340
    edited October 2009
    kawizx9r wrote: »
    You're going to need 2-3 coats of primer over MDF.
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    The first few coats of primer need to be light too. They are called tack coats to keep the primer from soaking too deep into the MDF.
    Ben
