Anyone want to try Silver Sonic IC's
NJPOLKER
NJPOLKER Posts: 3,475
edited October 2009 in The Clubhouse
I bought these from a fellow Polkie awhile ago and have no need for them right now. Instead of selling them maybe a fellow Polkie would like to test them out. They are 18" long, RCA's and in excellent shape. Let me know if you have an interest.
Here is some information on them.
Silver Sonic BL-1 Interconnect
SILVER SONIC BL-1 Series II Interconnect is a high performance audio interconnect cable that combines the highest sound quality and reliability available at its price point. In the tradition of our highly acclaimed SILVER SONIC T-14 High Resolution Speaker Cable, SILVER SONIC BL-1 is made in USA and uses the finest materials available, including high purity silver, Teflon and oxygen-free copper.
SILVER SONIC BL-1 is a balanced cable designed for use with both RCA and XLR connectors. It is 100% shielded, and can operate in close proximity to digital equipment without noise pick up. The conductors consist of slow drawn oxygen free copper, which are coated with pure silver, the silver coating thickness being chosen to provide optimum synergy with the OFC base metal. The conductors are insulated with a special Teflon copolymer dielectric.
Silver Sonic BL-1 uses large 20 gauge conductors for low signal loss. Every spool is tested, and our Teflon insulators are made to the highest standards in the industry. Cables are terminated with special silver bearing solders and the finest connectors available. Each connector is meticulously hand soldered by carefully trained craftspeople. Bulk lengths are also available for custom installations.
Color: Blue
Diameter: 5.5 mm
Recommended connector: DH Labs RCA-2C
Post edited by NJPOLKER on
