Tube Testers - Which ones and fair price
thsmith
thsmith Posts: 6,082
edited January 2010 in Electronics
Looking for recommendations for tube testers. EL34, 12AU7,12AX7, 12AT7 and such.
SOurces, makes and fair prices would be helpful.
If you have one your not using or an extra PM me.
Post edited by thsmith on
    SCompRacer Posts: 9,112
    edited October 2009
  • george daniel
    george daniel Posts: 12,096
    edited October 2009
    The Bug has bit you eh????
    mhardy6647 Posts: 35,047
    edited October 2009
    unfortunately, yez gets what yez pays for. If you want to be able to match output tubes, get a Hickok transconductance tester, and buy it refurbished/calibrated. Otherwise, I'm afraid you're pretty much just wasting your money. There are a couple of current products for matching certain output tubes; probably worth a look but I have no hands-on experience.
    If you just want a simple emissions tester and to check for internal shorts and grid leakage, I like the simple, rugged Sencore Mighty-Mite.
  • thsmith
    edited October 2009
    SCompRacer wrote: »
    Excellent read ! Thank you
    Real bad George. I am like an addict. I need more tubes, I need to measure bias, I need to roll tubes, I need to test tubes.
    Its a little crazy:o
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    thsmith wrote: »
    ya think!!!!! welcome to the Rabbit Holes darkest yet sweetest cooridors.
    RT1
  • thsmith
    edited October 2009
    Another good link on tube testers
    http://tone-lizard.com/Tube_Testers.html#Hickok1
  • dcmeigs
    dcmeigs Posts: 708
    edited January 2010
    I use B&K 707 Dyna Jets. I have two. For me they are the Gold standard. And if you have problems, I can fix and calibrate them. They test virtually every tube you will ever encounter in Audio.
    The world is full of answers, some are right and some are wrong. - Neil Young
