Replacement for recently deceaced RT3
amiti
amiti Posts: 24
edited November 2009 in Vintage Speakers
Hello,
As my polk RT3s passed away I was looking for a replacement. Two options were found localy for about 70$:
  1. Celestion Dl4 (1st generation)
  2. Boston Acoustics HD7
The celestions' sound very balanced but has a slightly thin unatural highs.
The Bostons' sound very tight but has less 'body' than the celestions'. During the audition I noticed one of the foam surrounds is loose . It is needed to be glued or maybe even replaced as the speaker is about 20yo.
I appreciate your knowledge and views. What do you think about these?
Post edited by amiti on
  • rooftop59
    rooftop59 Posts: 8,120
    edited October 2009
    I am not sure about the speakers that you reference, so this may not be very useful. However, I owned the RT3s for a time and I did like them, but not as much as either the newer Rt25i or the Rti4. My favorite of the 3 is the rt25i. I really like the tweeter in that series, and the powerport makes for some great bass from a small pair of speakers. These can be had on ebay for a great price if your patient (i.e under 100 bucks shipped). One other suggestion: I bought the rt3s to use as surrounds with the RT7s which serve as my mains at home. The RT7s are GREAT speakers. The bass is incredible, I really like the tweeter, and the imaging and soundstage are very good. It is a large speaker however, so look out for that. There is a pair on ebay right now for a very good price that I would snag up if I needed another pair:
    http://cgi.ebay.com/Polk-Audio-RT-7-Speakers-Pair_W0QQitemZ320435692257QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item4a9b74a2e1
    Hope that helps.
    Game Room 5.1.4:
    Bedroom 2.1
  • Disc Jockey
    Disc Jockey Posts: 1,013
    amiti,
    Did you end up replacing your RT3s? I have a badly damaged grill on one of mine and I was hoping you might have one you no longer have a use for. Let me know if you do and how much you want for it. Thanks.
    DJ
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • amiti
    amiti Posts: 24
    I still hope to have them repaired one way or the other.
